Oil & Fuel BX: How to Change Fluid with Loader?
   / BX: How to Change Fluid with Loader? #1
Plow Paul
Madison, Va
Kubota BX1850
I got my BX1830 new without a loader back in 2005. Late last year, I stumbled across a clean used LA211 loader for it. I had faith that the oil in the loader was clean as well, hooked it up and it worked great. Now I need to change the hydraulic fluid, but this is the first fluid change with the loader. Are there any special procedures for changing fluid with the loader? Thanks!:confused:
   / BX: How to Change Fluid with Loader? #2
Don't know about your model, but my little ford holds a tad over 5 gallons in the tractor and guessing about a gallon and a half in the loader. Unless your fluid looks really suspect, I wouldn't sweat it. It would be a real chore to drain the fluid from a loader since all the cylinders are DA.
   / BX: How to Change Fluid with Loader? #3
No special procedure -- same with or without loader.
Thanks for all your replies. I guess the fluids from the tractor and loader are well mixed by now! So I assume what little bit of fluid left in the loader cylinders will just mix right in with the new fluid and filter. I know, I tend to over-think simple matters!
2002 Alumitech Airboat with T/A Boat Trailer (A55853)
2002 Alumitech...
Welcome to the Ranch Decorative Sign (A55853)
Welcome to the...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A55315)
Case Wheels for...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2015 Dodge Journey Van (A55853)
2015 Dodge Journey...
