Oil & Fuel BX: How to Change Fluid with Loader?
   / BX: How to Change Fluid with Loader? #1
Plow Paul
Madison, Va
Kubota BX1850
I got my BX1830 new without a loader back in 2005. Late last year, I stumbled across a clean used LA211 loader for it. I had faith that the oil in the loader was clean as well, hooked it up and it worked great. Now I need to change the hydraulic fluid, but this is the first fluid change with the loader. Are there any special procedures for changing fluid with the loader? Thanks!:confused:
   / BX: How to Change Fluid with Loader? #2
Don't know about your model, but my little ford holds a tad over 5 gallons in the tractor and guessing about a gallon and a half in the loader. Unless your fluid looks really suspect, I wouldn't sweat it. It would be a real chore to drain the fluid from a loader since all the cylinders are DA.
   / BX: How to Change Fluid with Loader? #3
No special procedure -- same with or without loader.
Thanks for all your replies. I guess the fluids from the tractor and loader are well mixed by now! So I assume what little bit of fluid left in the loader cylinders will just mix right in with the new fluid and filter. I know, I tend to over-think simple matters!
Industrias America F10 (A56469)
Industrias America...
KUBOTA RCK48P-124Z 48" MOWER DECK (A57192)
KUBOTA RCK48P-124Z...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A55315)
Gleaner N630 Corn...
UNUSED FUTURE FT15 EXCAVATOR (A57192)
UNUSED FUTURE FT15...
3pt 11 Shank Chisel Plow (A56469)
3pt 11 Shank...
5' DISC HARROW (A57192)
5' DISC HARROW...
