BX Garden Plow?
/ BX Garden Plow? #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
Boy would I like to run a single plow with my BX2660. I think it has enough power, but it sits so dang low. My garden needs to be turned over, especially in the fall. I've only had a walk behind rototiller for the past 35 years and that's getting to be a lot of work for this old man.:eek: Do any of you BX owners plow?
/ BX Garden Plow? #2
/ BX Garden Plow? #3
Yes I do with my bx 2230.use a leinbach 1 bottom plow ,20" spacing, works well, tractor can lift it well.They are not easy to find used but new if you do a search should find some new. I use my R-4 tire's when the soil conditions are not to wet it pulls it fine.If wet you will struggle for traction.Bar tires would be better for this but for me most of my use does not require them.Trying to find a small disc 5ft is a real challenge but with some effort you will find one.Drag harrows are fairly easy to find even old 3 sections can be had for a very good price take one section off and your all set.My bx will pull 2 section's very well.You will spend some seat time for sure this way.A rear mounted tiller would also work fine. happy gardening.
/ BX Garden Plow? #4
I got this plow from Milkman. Traded him a like new Boxblade for it. He said he'd pulled it with a BX but I've never used it yet.
I've pulled a tiller with a BX and a Boxblade with the teeth down quite a bit with a BX.
/ BX Garden Plow? #5
/ BX Garden Plow? #6
dandy idea with ballasted subsoiler. Gives you a bit more traction when needed by just lifting with quarter inching lift. :thumbsup:
is that a rebar welded on there tom h?
/ BX Garden Plow?
:thumbsup:Thanks Gents. Being stuck indoors for the most part, except for pushing snow is getting to me. I've followed your evolution to the B2320 already BP and am envious of your garden successes. Thanks for the pictures and your experiences to the rest of you. What a dilemma! A plow.....or a new model B. I think I'll give the BX a chance. Over the years I've developed raised beds,mulched pathways and deer fencing. All that would have to be rearranged to make a pass. Arghgggg. :licking: Someday I might even learn or get geared up to post pictures too.
/ BX Garden Plow? #8
Here you go, this is the Allis Chalmers plow that I fitted a 3 point hitch for the BX, traded the IH plow to John, might have to go trade him out of it, could test drive the 1140.:thumbsup::thumbsup:
http://www.tractorbynet.com/forums/owning-operating/142592-plowing.html
/ BX Garden Plow? #10
With the snow we've had this year I might have more use for some type front blade/snow blade for the RTV1140 than the plow. You could hook it up before driving the 1140.:) Something/blade hooked to a Reese hitch. You know the way.
/ BX Garden Plow? #11
I don't have pictures, but I modified and old David Bradley 8 inch plow to work on my GC2400, it works well. Even with turf tires.
/ BX Garden Plow? #12
Yep, it's welded, but it's a piece of an old barbell bar, the regular old 1" American size, not that thick Olympic stuff. I got a neighbor who runs a little welding/machine shop in his spare time to do it. He's done a number of jobs for me over the years and charges about a third of what the big shops in town charge.
I bought the weights used really cheap too, some at a second hand sports equip. place and some off of Craigslist. I use a little clip that secures weights on the end of a barbell bar on top just in case I hit a bump or something.
Dueling Tree (A65640)
2008 TRITON TRAILER WACKER MGT2S GENERATOR (A65643)
2008 TRITON...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
2015 LeeBoy 8510C Asphalt Paver (A64553)
2015 LeeBoy 8510C...
Genie GS-3232 32ft Electric Scissor Lift (A64553)
Genie GS-3232 32ft...
2026 DEVELON DX27Z-7-US30 EXCAVATOR (A65053)
2026 DEVELON...
