BX front drive shaft
/ BX front drive shaft #1
ericbx1500
Michigan
BX2380, scotts 48
I have two quick questions. First, it doesn’t look like there are any zerk fitting to grease the front drive shaft u-joints. Is this because it doesn’t turn fast when in use? Are they a sealed u-joint? Second, is there a zerk fitting for the front axle pivot?
/ BX front drive shaft #2
The front axle pivot is within the axle housing and uses the common axle fluid as lubrication.
According to the Kubota service manual, the only grease lubrication point is the speed control pedal pivot.
Ford Tailgate Sign (A64127)
Ford Tailgate Sign...
Mini Excavator Ripper Tooth (A66285)
Mini Excavator...
Skid Steer Hitch Plate (A65640)
Skid Steer Hitch...
2021 SANY SY265C LC LONG REACH EXCAVATOR (A63276)
2021 SANY SY265C...
2019 FORD F-150 XLT CREW CAB TRUCK (A63276)
2019 FORD F-150...
Wilbeck 2109 12ft. Digger Disc Chisel (A65640)
Wilbeck 2109 12ft...
