BX front carry shelf
/ BX front carry shelf #1
psvines
Earlysville, VA
Kubota BX2660
BX2660
I’m looking for a carry shelf that attaches to the front of the frame. A place to occasionally carry stuff without having to attach the FEL. And would like to leave it mounted all summer while mowing and moving around the trailer and log splitter.
/ BX front carry shelf #2
A starter idea:
If the receiver was just below the front frame, and not sticking out, it could stay on with the FEL. There is only about 3 inches between the frame and the loader crossmember on my BX, when fully lowered.
Bruce
/ BX front carry shelf #4
Mount a step bumper receiver vertically behind the frame, then use this. Easy to take off, and no interference with the loader crossmember.
Narrow one:
Wide one
Bruce
A starter idea:
Bruce
I’ve considered a hitch but imagine it would rattle and bounce around. Hitches aren’t a solid connection. But thanks, it’s still an option.
/ BX front carry shelf #6
There are several anti-rattle devices for hitches. But I don't think I could hear a rattle over all the other noises when driving.
Bruce
/ BX front carry shelf #7
Bruce
Bruce
/ BX front carry shelf #8
A local farmer had a fabricator make him a front mounted box/shelf. He uses it to haul tools, potatoes, fertilizer, etc, when driving between the various fields he farms.
The box is interchangeable between his small Kubota B2100 and the bigger M7060. Both tractors have two pieces of square tubing mounted horizontally, facing forward and spread apart on the front above the front weights. Then the box just slides has two pieces of square tubing as well that just slides on the other pieces of tubing on the tractor. A pin trough both tubes keep everything in place.
It can easily be removed and while his tractors don't have loaders, there wouldn't be any interference with the mounts.
/ BX front carry shelf #9
I drill a 9/16 inch hole to the bottom of the receiver and then weld a 1/2 inch nut over it. A bolt keeps the hitch from rattling.
I like the idea of a receiver on the tractor's front since it can also be used for a winch using a hitch mount.
/ BX front carry shelf #10
A hitch up front really is a good idea.
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2006 Ford F-250...
New/Unused 76in Pallet Fork Extensions (A65583)
New/Unused 76in...
2013 John Deere 7200R Tractor (A66285)
2013 John Deere...
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A65579)
(1) HD 24ft Free...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
