BX coolant question
/ BX coolant question #1
andiamo
Kubota 1860
ok, my BX1860 is at the shop... over the weekend I discovered about 1/2 cup of coolant had leaked onto the floor. Best I could tell most of it had dripped down from the top of the water pump where the weep hole is... however, there was coolant around the bottom of the pump and on the radiator hose below... though my guess is it all came down from the weep hole. Coolant was low about 3/4" below low level... so I used the tractor for a few hours (it was a cool day) and the temp gauge never got above normal (about 1/2) nor did it leak any more fluid... as a matter of fact the heat from the motor dried up most of the previously leaked fluid.
Here's my question... the dealer can't get it to repeat the leaking problem. I don't know of anything other than a bad water pump seal that would make it leak out of that weep hole... but then again I'm no expert on such things. If the dealer wants to give it back and tell me there's no problem and he doesn't understand what happened (that's the feeling I'm getting)... should I accept it back and just watch it? Or should I demand that the water pump be replaced?
Thanks for your help and advice in advance...
David
/ BX coolant question #2
Unless you had done something odd that may have caused an over pressure condition (recent over fill, too high a cap, etc) then under similar conditions (put away hot) someday that pump will leak again. You got it there, were ready to buy the pump, go for it.
forgot to mention... it's only got 25 hours on it, so I don't plan on buying a water pump. I did give a pretty substantial workout on a warm day the previous week mulching leaves into my DR tow behind leaf machine... but never noticed the temp gauge go above normal, and I keep an eye on it due to what I've read on here about mowing/overheat issues. So my question really is do I force a warranty issue here on the pump?
2011 Chevrolet Impala Sedan (A59231)
2011 Chevrolet...
Toyota 7FGCU25 5,000 LB Cushion Tire Forklift (A59228)
Toyota 7FGCU25...
John Deere 1025R (A53317)
John Deere 1025R...
2017 Ford F-550 Bucket Truck - Power Stroke Diesel, ETI 40 Boom, 45 ft Working Height (A61306)
2017 Ford F-550...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
Harlo HP6500 (A60462)
