BX Bucket edge, Piranha tooth,pro or straight? Pros and Cons of each.
   / BX Bucket edge, Piranha tooth,pro or straight? Pros and Cons of each. #31
I have a piece of galvanized C channel I lay over my piranha toothbar when not in use. A heavy piece of angle could also be used for protection.
   / BX Bucket edge, Piranha tooth,pro or straight? Pros and Cons of each. #33
I am leaning towards the regular Piranha bar, I use the bucket for different tasks and I also am trying to protect my bucket. The Pro bar I don't think I can justify the extra cost. What are your guys thoughts for all around use.
Does the Piranha improve digging? Hinder back blading ?
Thanks
I'm spending your money here but if your tractor has an SSQA FEL, I'd buy a second bucket and equip it with the Pro bolt on bar. That way, you can swap buckets instead of fooling with bolts.
I had a bolt on tooth bar and found it hindered the back dragging work I do. As a result, I was constantly installing & removing it. To save time, I bought a second SSQA bucket and equipped it with the bolt on Pro.
Of course this depends on the type of work you do and the size of your budget. ;)
   / BX Bucket edge, Piranha tooth,pro or straight? Pros and Cons of each. #34
That's a pretty cool way to live.
ENCLOSED DRIVING SIMULATOR TRAILER (A58216)
ENCLOSED DRIVING...
Kubota SVL95-2 High Flow Cab Skid Steer (A55302)
Kubota SVL95-2...
LOT: (3) Water Meters, (2) Valves (A59076)
LOT: (3) Water...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
3 Row Twin Row Renaldo Planter (A53317)
3 Row Twin Row...
1707 (A58375)
1707 (A58375)
