BX Bucket edge, Piranha tooth,pro or straight? Pros and Cons of each.
   / BX Bucket edge, Piranha tooth,pro or straight? Pros and Cons of each. #31
I have a piece of galvanized C channel I lay over my piranha toothbar when not in use. A heavy piece of angle could also be used for protection.
   / BX Bucket edge, Piranha tooth,pro or straight? Pros and Cons of each. #33
I am leaning towards the regular Piranha bar, I use the bucket for different tasks and I also am trying to protect my bucket. The Pro bar I don't think I can justify the extra cost. What are your guys thoughts for all around use.
Does the Piranha improve digging? Hinder back blading ?
Thanks
I'm spending your money here but if your tractor has an SSQA FEL, I'd buy a second bucket and equip it with the Pro bolt on bar. That way, you can swap buckets instead of fooling with bolts.
I had a bolt on tooth bar and found it hindered the back dragging work I do. As a result, I was constantly installing & removing it. To save time, I bought a second SSQA bucket and equipped it with the bolt on Pro.
Of course this depends on the type of work you do and the size of your budget. ;)
   / BX Bucket edge, Piranha tooth,pro or straight? Pros and Cons of each. #34
That's a pretty cool way to live.
2015 Toro Greensmaster 3150 Commercial Reel Mower (A56857)
2015 Toro...
2016 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52709)
2016 CATERPILLAR...
2017 FREIGHTLINER M2 106 (A58214)
2017 FREIGHTLINER...
CASE MXM 190 TRACTOR (A58216)
CASE MXM 190...
40' CONTAINER (A58376)
VERMEER RTX100 WALK BEHIND TRENCHER (A52709)
VERMEER RTX100...
