BX 25 Is there a cover that will cover everything including backhoe?
   / BX 25 Is there a cover that will cover everything including backhoe? #1
JOE G
Eastern NY
Husqvarna / John Deere
Hi,
I would like to get a cover that will cover the whole tractor for the times I may need to leave it outside for extended periods. My large equipment I don't worry about it as they have cabs or sit in one of my pole barns. The BX I tend to lend to family or friends and it may stay outside for a couple weeks at a time in all kinds of weather. I would like to find a cover that will cover the machine with the back hoe on.
   / BX 25 Is there a cover that will cover everything including backhoe? #2
Assuming you don't want to just tarp it. Check with a canvas shop that does boat covers. If you could leave the tractor there, they could make you a custom cover.
I did that for my log splitter. It was pricey, but I never regretted it since it sits outside all the time.
Doug in SW IA
   / BX 25 Is there a cover that will cover everything including backhoe? #3
If you loan it out, send a tarp with it. If they won't cover it with a tarp, they probably wouldn't cover it with a custom made or fitted cover.
Is mice an issue in your area? Covering it with a tarp or cover all the way to the ground is going to increase humidity issues along with access to critters you really don't want around your machine.
David from jax
   / BX 25 Is there a cover that will cover everything including backhoe? #4
I made the mistake of covering a 2 horse trailer with a custom cover. Once i removed the cover i found lots of mouse nests under cover, all screens in trailer eaten away and the think smelled of mouse pee for a long, long time.
   / BX 25 Is there a cover that will cover everything including backhoe? #5
Kind of my thoughts, although we don't have mice issues here (which is surprising due to the amount of corn we put out daily).
I would think one or two of those 10x10 collapsable tent coverings set up end to end might be better but unfortunately, those things don't hold up in the wind.
David from jax
When I was 16 I had a nice Black car that I didn't run in the winter, I made the mistake of covering it with a tarp, Well in the spring I ended up having the whole car re painted. I know this is a tractor and not a shiny sports car. I know a lot of tractors sit out their whole life, Parking it in the shade probably would help it some. I figure these little tractors hold their value and I may sell or trade it in at some point figured If I kept it nice that would help.
   / BX 25 Is there a cover that will cover everything including backhoe? #7
I just serviced and wash/waxed my 2010 dk45 last Tuesday. It still looks fairly new even with 1650 hours. Thats why i keep it under a lean too. The sun just destroys the paints.
   / BX 25 Is there a cover that will cover everything including backhoe? #10
Check with these guys:
2004 FORD E350 MECHANICS TRUCK (A52576)
2004 FORD E350...
E-Z-Go Freedom TXT Electric Golf Cart (A51694)
E-Z-Go Freedom TXT...
2019 Kubota RTV-X1140 4x4 Utility Cart (A51691)
2019 Kubota...
BUSH HOG 7007 LOT NUMBER 115 (A53084)
BUSH HOG 7007 LOT...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
