Stradbash
Hi Folks,
I've had my BX 25 for about 10 days now..., but with the ground thawing as it is I've restrained myself from messing up my yard and have had to be content with installing my Bro-Tek skid plates etc.
One problem I've run into (and it could well be simple ignorance) is that I've not been able to figure out where the "block heater" that Kubota specifies for the BX 24 & 25 (part # 70000-73595) is supposed to be installed. The directions say to remove the "front plug located on the front side of the cylinder head, next to the air intake breather". I see no freeze plugs on the cylinder head near the air intake. I do see one on the front of the cylinder head, but there is not enough room for the upper end of the heater and connector between the head and the muffler. There are two freeze plugs on the left side of the -block- near the air intake, but they are 25 mm or so in diameter and too small for the heater to fit into. The diameter of the heater I have is 30 mm, the diameter of the freeze plugs on the left side of the block are 25 mm or perhaps 1".
My dealer is looking into this but the poor guy injured his knee, is being harassed by his ruthless coworkers and should not even be on his feet let alone at work so I'm hoping to help him out...
Any insight would be appreciated!
