Backhoe BX 25 backhoe?
/ BX 25 backhoe? #12
Maybe you can modify the bh to work as a wood splitter. Or maybe as a boom string trimmer style.
/ BX 25 backhoe?
Radioman- Now that's something I never thought of. That might be something to do with it when my welders/etc. get replaced.
/ BX 25 backhoe? #14
Undetermined cause of fire according to ins. investigator. Most likely my ceiling heater. Can't buy BX25 without -comes standard TLB.
Ahh... I thought you could buy a BX2370 with FEL only and then put your 'old' BH on. Maybe it doesn't work that way? Maybe there is something different between a BX2370 and a BX25D?
/ BX 25 backhoe? #16
RAECOREP, sorry to hear about this,
you may not be able or want to, but you should see if you can keep or remove the subframe for the hoe,
you may have better chances of selling it if it came with the quick attach frame,
it could then be modified for another type machine, just a thought.
/ BX 25 backhoe? #17
There u go that's an idea!
/ BX 25 backhoe? #18
If you decide to sell, I have a BX2370. I would be interested. Just lemme know.
/ BX 25 backhoe? #20
For the new reader - I made a decision to go a different direction. Its still for sale as far I know. Good luck to you Raecorep!
Coats 5060AX Rim Clamp (A61307)
Coats 5060AX Rim...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
Volvo L45H (A61307)
Volvo L45H (A61307)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
