BX-24 RPM Question
   / BX-24 RPM Question #22
One of the changes from the 23 to the 24 was the addition of a tachometer.
   / BX-24 RPM Question #23
That is why the Kubota service rep said what he said. .
I see a common thread where Kubota prints one thing in their "official documents" then their "official representatives" tell us something else. Engine oil weights are another example. They really need to get their act together on this.
   / BX-24 RPM Question #24
That's what I've noticed. Why are they saying the opposite of what the owner's manual states. The cavitation theory doesn't make sense to me 'cause there would be more at higher rpm's than lower. I could be wrong, but it makes more sense to me that the lower rpm's means less hydraulic flow and pressures meaning longer hose, trans, engine, and fitting life.
   / BX-24 RPM Question #26
I just re-read my manual and it states for Backhoe use run 75%-100% rated RPM. If below 32deg F run at 50% rated RPM until Oil warms up. Rated RPM is 3200rpm so that is a range of 2400-3200rpm. It also states that it is most efficient at 100% rated speed.
74in FEL HD Round Back Bucket (A51039)
74in FEL HD Round...
2011 FREIGHTLINER CORONADO(INOPERABLE) (A50854)
2011 FREIGHTLINER...
2015 PETERBILT CLASS 8 CEMENT MIXER TRUCK (A51243)
2015 PETERBILT...
2012 Ford F-550 4x4 Versalift VO36I-01 36ft Insulated Bucket Truck (A49461)
2012 Ford F-550...
1986 John Deere 772B Articulated Motor Grader (A49461)
1986 John Deere...
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
