BX-24 Hood Adjustment
   / BX-24 Hood Adjustment #1
DickS
U.P. MI
JD 265, Kubota BX24
The hood on my BX-24 rubs against the front of the cowling. I can't seem to find any adjustment other than to shim the hood lift assembly by placing washers under the 4 bolts that attach the hood lift assembly to the chassis member located just above the muffler.
Anybody else have this issue?
   / BX-24 Hood Adjustment #2
I have the same issue on my MF. I was able to adjust the hood catch up on one side, but the Kub is different I think. Anyway now I have a big gap on one side of the cowl, underneath the hood, and the other side fits flush. But now it sits even across the instrument panel. So much for fit and finish:confused3:.
   / BX-24 Hood Adjustment #3
I had this problem after I removed my hood. I fixed it by loosening the two black knobs that hold the cowling on and sliding the cowling a little bit aft. Do you have any room to do this? You can see the two knobs in the photo.
No, there isn't any more room to slide the cowling toward the rear. It is at the end of the slot.
   / BX-24 Hood Adjustment #5
Shimmed mine too. No more squeaking as the hood raises from rubbing on the cowling.
Manac Walking Floor Trailer (A50322)
Manac Walking...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2013 PETERBILT 388 (A52472)
2013 PETERBILT 388...
Kuhns AE10 Small Square Bale Accumulator - 10-Bale Efficient Handling System (A52748)
Kuhns AE10 Small...
2016 Hino 195h Truck, VIN # JHHSPM2H5GK001607 (A51572)
2016 Hino 195h...
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
