BX 2350 Tire chain question
/ BX 2350 Tire chain question #1
BadgerBX
Has anyone put either front or rear tire chains on their BX 2350? I'm having all kinds of traction issues this winter while plowing and I know chains would help. I question whether there is enough clearance for chains. I assume some sort of tensioner is a must....but even with it seems pretty tight.
Any success stories out there????
/ BX 2350 Tire chain question #2
I've had chains on mine for two winters and I've had no problems.
Thanks.....do you have them on front and back? Did you get the chains from a dealer or use a supplier....like tirechains??
/ BX 2350 Tire chain question #5
I just recently purchased some 2-link cross chains for my BX2660, and it's like a whole new tractor. They took a bit of doing to get on, but once I read the instructions, the snow quickly surrendered. My dealer got me a set for $170 + tax, which I thought was pretty good. I've had a number of people tell me I probably should have gotten ice chains, but I don't think I'll acutally need them; the cross chains seem to give me more than enough traction for my minimal grades.
/ BX 2350 Tire chain question #6
on my 3rd winter with tirechains.com chains on the rear, big improvement on the ice with R4's and the 3pt blade. I also got the tension springs, chain install is very easy. Very happy with the upgrade :D
/ BX 2350 Tire chain question #7
If you buy 2-link, you will not need tensioners, if they are installed tightly. (rear wheels)
4-link, you probably will.
The proximity of the steering linkage to the front rim makes chain installation there almost impossible.
Thanks.
I will go with 2-link on the rear.
