BX 2350 Engine RPM
/ BX 2350 Engine RPM #1
Jibber
RD-13, Putnam County, New York
Kubota L3130HST 4WD, BX2350
Hey, you BX people..
I'm interested in what engine RPM you run while mowing, and while using a rear PTO. I'm used to the L series where you can get a readout of the PTO speed. I'm not sure how that translates into Engine RPM. The manual rates HP at 3200 rpm.. but says nothing about where to run it with PTO implements. I guess with the mower it's where your comfortable. But I have a PTO chipper that's pretty particular for 540rpm.
/ BX 2350 Engine RPM #3
I was wondering the same thing on my BX1850 that I just got.
I mowed this weekend and ran at full throttle but wonder if I need to. In low full throttle floored seemed to be a good mowing speed for me.
Mowed a little at 2800 and seemed to work fine as well.
/ BX 2350 Engine RPM #4
You can get by at 2800 if your blades are sharp.
I usually mow at just over 3000 on my BX2200 but use high range.
/ BX 2350 Engine RPM #5
I've been running at 2900 rpm on my 2350 but that has more to do with only having 4 hours on the meter.
I'm able to cut at full speed in low range pretty well.
I did notice that when the blades come from the factory they don't seem to be overly sharp. I haven't taken the time yet to sharpen them. Has anyone else noticed this?
rdsaustintx said:
When mowing with a BX, all WOT all the time. Cuts way better.
I noticed that... higher rpm and it seems to mulch up what's in there much better.. less of the cut grass laying around afterward.
I'm trying to run around 3000 during the first 50 hours.
I was thinking of using the BX for some PTO chipping this weekend.. but I think I'll pull out the Grand L. Not sure I want to run at high RPM for 4 hours straight under load while still breaking in.
/ BX 2350 Engine RPM #8
These BX engines are designed to run @ 3k to 3.2K rpm all day long and they do it very frugally too.
When I mow w/my BX23 I run it at just a touch below full throttle. Since I don't have a tach I couldn't tell you the rpm but I'm gonna guess it's around 3k rpm. When I want fast BH & FEL response I'll run it about 3 touches below WOT as I've found this to be a good compromise between speed, power and sound. For normal FEL operation I probably run around 1/2 throttle.
I agree, I wouldn't advise this either during break-in. Some folks believe in breaking them in just like you're gonna work it but not I. I defer to the engineers what designed it and for my 1st 50 hrs there wasn't any WOT or anywhere near it on my machine.
But, with all that said, after it hits that magical 50 hr plateau, run it WOT all day long if you need to and all it'll do is ask you for more :D
Probably be more frugal than the Grand L at that :D
A BX and a Grand L, sounds like a good combo to me.
/ BX 2350 Engine RPM #9
My manual specifically states to NOT run the engine at full throttle for the first 50 hours, so I didn't.
I typically mow at around 2600 RPM.
/ BX 2350 Engine RPM #10
No freakin' clue. Idle is about 1:15 and WOT is about 3:42.
I do most of my work about 3:00. Sometimes if I'm in a hurry to get the mail or need that extra little bit out of the BH, I'll shift her to 3:42.
3:42 is where the real business happens. But I mow at 3:00. Much quieter and I can't say I notice a difference in mow quality. And 3:00 certainly provides enough mowing ground speed.
So my answer to your question is 3:00.
/ BX 2350 Engine RPM #13
I know the "Why do I love TBN" thread is log since closed... but driving into work this morning - I thought to myself... gee - using the L this weekend was nice - right on the tach it tells you where the correct RPM setting is for rear PTO speed... And I know my BX doesn't have that... wonder what it would be..
Poof - this thread...
Thanks yall!
BX2230_Lockport said:
540 at the rear is 3068RPM, and 2500 Mid PTO is 3125 RPM
This is for the BX2350, BX1850, BX2230, BX1830, BX24 and BX1500. For the BX23, add an additional PTO revolution for the same RPM's.:D
Thanks yall!
You know, the BX could use instrumentation similar to the L. How much more could that cost them? They make watches that do millions of things for 30 bucks.. it's a chip.. not a big deal.
I noticed the New Holland's of the same size and power as the BX series have much better instrumentation. I mean..we are talking about a tractor here.. not a lawnmower.
/ BX 2350 Engine RPM #15
Jibber and Fish,
I'm doing similar, keeping my RPMs a little lower during break-in, I am at approx. 20 hrs.
Mowing anywhere between 2850 and 2950 RPM...using 3000RPM as my "wall" during break-in. Using High range too, mowing fine, no raggedy cuts.
I mow at 3.5" tall, grass grows slower that way, and that means less mowing, which is where the real fuel savings happens. ;)
I have noticed, compared to my old Ford 1210 4WD, the BX2350 really is fuel efficient.
SkunkWerX said:
Jibber and Fish,
When I bought the BX it had a full tank and had barely budged off "F" after two mows. Then I used it for 3 hours with the chipper/shredder (PTO) .. It dropped to almost a half tank.. sooooo.. I guess it makes a big diffo how much load you put on her.
/ BX 2350 Engine RPM #17
I chalk that up to the sending unit. Mine does the same thing. It reminds me of my wifes previous car, it would stay on full forever then start to drop quickly. I think it's just the way the sending unit works in these tractors.
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
2022 KUBOTA SVL75-2 SKID STEER (A65053)
2022 KUBOTA...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
