BX-23 !@!$%@% hydraulic filter location!
/ BX-23 !@!$%@% hydraulic filter location! #1
jhb
MA
BX23
I thought I was charmed. I went through last season (100 hours) with none of the reported problems people post here. But in the last two months, I have had two!
The Air filter bracket broke. Instead of fixing, and fixing, and fixing, I opted for a $2.00 rubber tie down and wrapped it up, works just fine.
Yesterday, I hit a rock square on the hydraulic filter. It did not punture the filter, but it bent it so the seal failed. Fluid everywhere. I dumped as much soap in the area as I could to prevent it from killing too many plants.
Question, the oil filter top bent so the filter "wobbles" as you screw it on and off. Does anyone think I might have bent the mounting threads? I hope not!
Now I am just waiting to get a stick caught in the plastice fan under the drivers seat!
/forums/images/graemlins/shocked.gif
/ BX-23 !@!$%@% hydraulic filter location! #2
Hi jnb,
Get a new filters & put it on, if it still "wobbles" then new parts will need to be ordered.
Send me an email at Bro-tek@hotmail.com , so I can send you info on a skid plate, you should not have to go throught this again.
Bird
/ BX-23 !@!$%@% hydraulic filter location! #3
Having the skid plate gives me peace of mind in the woods.
/ BX-23 !@!$%@% hydraulic filter location! #4
Here a first look at the new and improve version, for the MMM.
/ BX-23 !@!$%@% hydraulic filter location! #5
lucky you! if the filter wobbles then it's the filter thats bent. if it didn't you'd be putting on a new housing with the filter.-Matt Jr.-ASE Master Automotive tech.
I hope that's the case. Won't know until I get a new filter this weekend.
/ BX-23 !@!$%@% hydraulic filter location! #7
So, what's the verdict?
/ BX-23 !@!$%@% hydraulic filter location! #8
I'll let you know as soon as I figure it out. I picked up the filter and UDT on Saturday, but here in NE it has been raining, HARD for three days! The tractor is sitting where it broke down because I did not want to damage anything when the hydo fluid spilled out.
I think I have had 10 -12 inches here at the house. Never seen so much water!
I got lucky. The hydro filter took the brunt of the knock, the new filter went on straight and true. I think I may have to consider the above mentioned skid plate. I am sure this can happen again, with all the rocks on my property.
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
Peterson Horizontal Grinder (A62613)
Peterson...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
2002 Dodge Ram Crew Cab Pickup Truck (A61573)
2002 Dodge Ram...
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
