BX 2200 Axle Problem?
   / BX 2200 Axle Problem? #1
NY_Yankees_Fan
Warren County, NJ (60 miles from NYC)
Kubota BX 2200
The tractor was 2 years old on 3/7 has about 175 hours. When I turn the steering wheel I have a rough spot or resistance when turning the wheel left or right. Much worse without moving but still has a resistance when moving. I recall someone talking about a problem with rusty axles and a recall but not sure how they determined the problem and what symptoms they had. Can anyone help?
   / BX 2200 Axle Problem? #2
Tom; I don't know anything about the rusted axles, but a number of tractors of your vintage had bad steering cylinders. I believe most of them had some steering failure, I can't remember whether any one had sticky spots as you describe.
Will
   / BX 2200 Axle Problem? #4
Tom,
I had a bad steering cylinder (that I replaced myself). The symptoms were quite different from yours: you could slowly turn the steering wheel and the tractor would continue in whatever direction it was pointed in. You had to crank on the steering to convince it to turn. There was no undue resistance on the wheel from this.
Jim
Talked to my dealer, he has the parts on order and he will send a mechanic to my house to replace the unit. Great service considering he is a 2 hours away. I noticed today if I turn the wheel left or right all the way, the wheels stop turning, but the steering wheel continues to turn. I assume this is not normal?? Hope the parts come in soon, seems to be getting worse. /forums/images/graemlins/frown.gif
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2016 CATERPILLAR 325FL EXCAVATOR (A51246)
2016 CATERPILLAR...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2012 Ram 1500 Crew Cab Pickup Truck (A53422)
2012 Ram 1500 Crew...
Carnival Ticket Booth (A51691)
Carnival Ticket...
