bx 1830 mower deck removal
/ bx 1830 mower deck removal #1
Proletarian
North of Atlanta
BX-25 / BX-1830
I'm curious and I dont have the manual for the deck. I can see the front latch and the lift arms need to come off but what about the shaft, where and how does it disconnect? I figured I ask here to streamline the operation :laughing:
/ bx 1830 mower deck removal #2
The collar attached to the pto shaft slides toward the front of the tractor to release the shaft. I've always found it awkward to remove because, in addition to just being difficult to reach, you have to kind of push on the shaft toward the rear while pulling the collar forward.
Also, I've read posts on here about collars that didn't lock properly when reattaching to the pto shaft and flying off and destroying the trans oil filter, so make sure when you reattach the collar it is locked on by giving it a good pull.
/ bx 1830 mower deck removal #4
Assuming yours is the same as my 2360, there are also 2 pins that you pull and rotate to release the deck from the 3ph linkage.
thanks for all the info. All worked out well. I was able to power wash under the deck and clean and regrease thoroughly. :thumbsup:
thats awesome, thank you. I will procure a set. :D
2009 INTERNATIONAL WORKSTAR BUCKET TRUCK (A63276)
2009 INTERNATIONAL...
2023 Kubota KX057-5 Compact Excavator (A63689)
2023 Kubota...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
