bx 1830 mower deck removal
/ bx 1830 mower deck removal #1
Proletarian
Bronze Member
North of Atlanta
BX-25 / BX-1830
I'm curious and I dont have the manual for the deck. I can see the front latch and the lift arms need to come off but what about the shaft, where and how does it disconnect? I figured I ask here to streamline the operation :laughing:
/ bx 1830 mower deck removal #2
The collar attached to the pto shaft slides toward the front of the tractor to release the shaft. I've always found it awkward to remove because, in addition to just being difficult to reach, you have to kind of push on the shaft toward the rear while pulling the collar forward.
Also, I've read posts on here about collars that didn't lock properly when reattaching to the pto shaft and flying off and destroying the trans oil filter, so make sure when you reattach the collar it is locked on by giving it a good pull.
/ bx 1830 mower deck removal #4
Assuming yours is the same as my 2360, there are also 2 pins that you pull and rotate to release the deck from the 3ph linkage.
thanks for all the info. All worked out well. I was able to power wash under the deck and clean and regrease thoroughly. :thumbsup:
thats awesome, thank you. I will procure a set. :D
Rotary Brush Cutter Tractor Attachment (A61572)
Rotary Brush...
2003 International 4300 Flatbed Dump (A62613)
2003 International...
John Deere 410D Backhoe (A62679)
John Deere 410D...
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2019 KENWORTH T680...
2013 Ford F-350 Knapheide Service Truck (A61573)
2013 Ford F-350...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
