BX 1800 hood shake
/ BX 1800 hood shake #1
Anonymous Poster
Epic Contributor
I test drove a BX 1800 a few days ago and one thing that I noticed was that when the engine was idling, the hood shook quite vigorously. When it was throttled up some, it was smoothed out nicely. I have no previous experience with the BX tractors, and was wondering if this is normal? My Dad has a 1225 MF that I've spent some time on, so I do have at least something to compare to. The Massey is smooth no matter what RPM it's running, so the hood shaking like it did on the BX kind of surprised me. Also, this tractor had almost 7 hours on it. Is it still considered "new"? I know that's not a lot of hours for these tractors, but it seems like quite a bit for a "new" tractor. Any non-flaming input is appreciated.
/ BX 1800 hood shake #2
Dunno but my L1501 (L185) hood shakes bad when I drive over rough ground (all the time) And ideas on how to fix it too would be appreciated.
There are no clamps, it just seems to sit down.
<font color=blue>Neil from OZ.</font color=blue>
/ BX 1800 hood shake #3
The hood on my BX 1800 doesn't shake at idle unless it isn't latched all the way. The only time the hood shakes is when I shut it down. As for it having 7 hours, sounds like it must be a demo unit. When I bought my BX 1800 it came delivered to me with .8 hours on it. If it would have had anymore than 1 hour I would have questioned it because I'm buying new not used or demo.
Thanks for the replies. As far as the hours go, that's what I thought too...7 hours is at least 6 too many for a new tractor.
/ BX 1800 hood shake #5
My BX2200 will occasionally have a hood rattle when the throttle is at its lowest setting. My guess is that the lowest throttle setting varies slightly between units. Without a tach on the BX it's impossible to tell though.
Simple fix - move the throttle about a quarter inch.
Patrick
/ BX 1800 hood shake #6
At its lowest throtle setting, my BX2200 hood rattles like 1 inch hailstones on a tin roof. Which is why I never set the idle that low.
<font color=red>Winnipeg, Manitoba</font color=red>
2001 BX2200 (50 hrs)
/ BX 1800 hood shake #7
My BX 2200 has a hood rattle at idle. There is a partial fix for the problem mentioned somewhere on this board. You might search for it if needed. I installed two self drilling screws in the hood over the rubber bumpers. You can then adjust the screws to provide more tension on the hood latch which will modify the rattle some. It still rattles but not as bad as before.
I think the hood rattle stems from those springy motor mounts being a little too resiliant, the motor really shakes around at idle and when shutting down. I did tighten up the fit on my BX hood by squeezing the sides together slightly at the rear of the hood. It fits nice and tight when closed and the only time it rattles now is when shutting down the engine, but my remedy for that now is to simply hold a little side pressure on the hood with my left hand while turning the key off with the right. Maybe Kubota should include this proceedure in the operator's manual on next years models.
/ BX 1800 hood shake #9
My BX2200 rattles at idle. It's only a 3 cylinder, so compared to a 4 or 6, you are going to get more shake at idle (fewer power strokes per rev). It also rattles like crazy when you shut it off. Mine had 1.6 hours on it. The dealer only had one, and it was delivered to me. It was splotlessly clean though. Smaller dealers may only keep on on hand and they demo it a little and sell it as new. Maybe bigger dealers have a dedicated demo unit. 7 hours seems 'used'.
- Patrick W.
/ BX 1800 hood shake #10
I can understand folks wanting "brand new" when they buy a new product, but I guess I'm a little different. The dealer has to do some assembly and set up, install the FEL, etc. and I TOLD them I hoped they'd play with it awhile (preferably a couple of hours), even move some dirt. After all, it was going to be under warranty and washable, so I'd rather they found any little problems or leaks BEFORE delivery.
Bird
/ BX 1800 hood shake #11
Re: BX hood shake
My BX shook too, when I bought it, but i fixed itby buying some of those self-adhesive rubber feet and putting them on the tractor, where the hood sits when latched. This forces me to push down on the hood to latch it, but it works great. No more rattle!
/ BX 1800 hood shake #12
I just put a little self adhesive foam weather stripping tape on all the surfaces where the hood could rattle against the body of the BX2200. Now it is silent -- no rattle. Home Depot carries it.
/ BX 1800 hood shake #13
My BX2200 had the "rattle" also. A simple fix, which was mentioned on this board is to very very slightly bend the hood inwards on the side of it. Take one hand on either side and a very little push. What this really does is make a tighter fit on the latch.
I did this and no rattles anymore. Even at idle.
-Mark
2017 Chevrolet Silverado 1500 Pickup Truck (A64194)
2017 Chevrolet...
2018 JOHN DEERE 35G EXCAVATOR (A65053)
2018 JOHN DEERE...
1997 Volvo WG Day Cab Truck Tractor (A64194)
1997 Volvo WG Day...
72in. Fork Extension (A64553)
72in. Fork...
2015 Ford F-150 Pickup Truck (A64556)
2015 Ford F-150...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
