Bx 1500 engine roll ?
/ Bx 1500 engine roll ? #11
</font><font color="blue" class="small">( POWER SERVICE????....Junkman....what is that??? )</font>
I'll answer for him. /forums/images/graemlins/wink.gif Go to Power Service and read all about it. My neighbors and I all used it all the time.
/ Bx 1500 engine roll ? #12
Are you using the entire line of products? Which products do you find the most valuable?
/ Bx 1500 engine roll ? #13
Barry, the only one of their products I used, and the only one I know of my neighbors using, was the Diesel Fuel Supplement that you can buy at Tractor Supply Co., Wal-Mart, and lots of other places.
/ Bx 1500 engine roll ? #14
I dont know, Seems to me the Delvac is all the engine protection a diesel needs. In my opinion its great.
Besides Junkman, This shake rattle and roll seems to be normal with everyone. As violent as my shut down is I would be hard pressed to think using a different oil would stop it. Hey Junkman, when yours was new, did it have a violent shut down? Or was it smooth from the get go?
/ Bx 1500 engine roll ? #16
I remember it being more "abrupt", but how much, I can't say. That was last fall and I have a hard time remembering last week. I did think of one thing that might be making the difference. When I shut it down, I leave the tractor in gear. I know that this makes a big difference with gasoline engines that have a habit of "dieseling"
/ Bx 1500 engine roll ? #17
Leaving the tractor "in gear" will make no difference, that only disconnects the gear box from the HST drive unit. The HST drive unit is always engaged on the BX (it has no clutch disconnect like other Kubota models) so there is always a "load" on the engine(although small since the unit is in hydrostatic neutral when you shut down, but a load none the less) this is assuming you are stoped when you turn off the machine. Just raise the engine speed a bit and see if you can find a good shutdown RPM that reduces the amount of "roll" you are experiencing.
/ Bx 1500 engine roll ? #18
<font color="blue"> Just raise the engine speed a bit and see if you can find a good shutdown RPM that reduces the amount of "roll" you are experiencing.
</font>
If I raise the rpm on my BX a little it smooths out real nice when running. At lowest RPM is is rough and I can understand why air cleaner brackets are failing...
But regardless of speed when turned off, that shake/rattle/roll is still there and pretty amazing at that. Now my B2910 when turned off at any speed just stops quietly without any rattle at all...and I think using that as a reference is all the worse for me...
I don't know why the BX shakes so much...do all 3 cylinder Kubota engines do this?
I remember when my bx was delivered and we were getting a guick run trough on operations. I was amazed in its shut down roll. I should have asked then, but did not. I was told to lower the rpm all the way and wait a minute then shut down. I do this with no avail. I guess I will just have to ignore it, and hope for the best. Who has the oldest bx and what problems have you had?
/ Bx 1500 engine roll ? #20
I notice also that our new BX1500 shakes a bit on shut down and that it idles with a bit more vibration than our B2910. I agree that the high compression and smaller mass of the engine probably causes this (as the 2910 is very smooth on start, idle and shut-down). On balance though, I sure like the BX1500. It's a little titan of a tractor and sure does a nice job on the grass.
2013 Ford F-150 Pickup Truck (A59230)
2013 Ford F-150...
2017 Peterbilt 320 T/A E-Z Pack 40Yd Front Loader Garbage Truck (A59230)
2017 Peterbilt 320...
1408 (A57192)
1408 (A57192)
Mini Margaritaville Truck (A55853)
Mini...
2018 Yamaha VX1050B-TA Waverunner Jet Ski with2010 trailer (A59231)
2018 Yamaha...
Deere 35P (A53317)
Deere 35P (A53317)
