Buzzing Ignition when key turned on, NO Start CT230?
   / Buzzing Ignition when key turned on, NO Start CT230? #11
I have used No-Ox-Id probably over 40 years both professionally and personally on every battery I have ever owned. These stories about corroded cables and no start conditions just make me shake my head, when the solution is so simple and I have been an apostle for this product for decades.. But I guess people cannot believe that such a destructive problem can be solved so simply by using a "magic" product. But it IS magic.
   / Buzzing Ignition when key turned on, NO Start CT230? #12
I believe you....
I bought it and its the best investment I have ever made
I do not make an electrical connection that sees any sort of environmental contaminant that I don't coat with it!
I guess my jihad against corrosion did not go in vain. Go forth and spread the gospel. :)
   / Buzzing Ignition when key turned on, NO Start CT230? #13
It truly is James, I have told my peers at work about it as well.
All I can say is people who ignore you does it at their own peril
   / Buzzing Ignition when key turned on, NO Start CT230? #14
I believe you James.... about $8 on eBay.
I also think there should be a sticky explaining Ohms Law and the use of a DVOM. The meters are free at Harbor Freight I have about 7 of them. One in each building and one in each vehicle.
   / Buzzing Ignition when key turned on, NO Start CT230? #15
There yopu go James, at least two converts that you have made.
Even Jesus did not create Christendom over night!
:D
   / Buzzing Ignition when key turned on, NO Start CT230? #16
I agree with you 100%. I believe ohms law and simple DC electric should be taught in the 8th grade as a part of 8th grade science. It would take just a few days of theory and lots of hands on and it would do a world of good in the world. Far more good than many other things that are covered.
   / Buzzing Ignition when key turned on, NO Start CT230? #18
Well, looks like one believed me :) I didn't lie did I ?
Well, if I would have seen this before I bought the spray paint stuff at AZ, I would have followed your advice. I recently bought a cable/battery cut-off switch. It is a weird sort of extension that just uses battery clamps. I have replaced the positive side twice, and the cable is now very short. So this should extend the clamp, and give me a cutoff to help keep the battery charged while I am away. Maybe a minor anti theft deterrent also. I will post a pic of it, if I ever get it installed. Should not take but a few minutes.
   / Buzzing Ignition when key turned on, NO Start CT230? #19
I looked at putting one of those on mine the first time my cable went bad.
Thats when James told me about No Ox, I just purchased a new cable and wal-la, no more problems.
I like a battery maintainer on mine anyways to keep the battery up, that was another awesome bit of info I have learned off of TBN
   / Buzzing Ignition when key turned on, NO Start CT230? #20
Ive got battery tenders and extension cords running all over the barn. Honda Big Red, Lawn Tractor, Jon boat, and two batteries sitting from a camper on tenders. I should just go ahead and bite the bullet and put the Bobcat on a tender also.
Jeff
2011 CATERPILLAR CP56 PADFOOT ROLLER (A60429)
2011 CATERPILLAR...
2014 Ford Edge SUV (A56859)
2014 Ford Edge SUV...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
Compressor (A55973)
Compressor (A55973)
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
