Buying Used Rotary Mower
   / Buying Used Rotary Mower #1
RidgeHiker
Upper California Mountains
Kioti DK5010 with KL5510 Loader & 72" Bucket. Kawasaki Mule Pro MX SE with 66" snow plow.
I have never owned or used a rotary mower. I have a small project on an acre or less with oaks, low brush, manzanita, tons of oak leaves, etc. that I need to prep for fire safety (Northern Calif.). At most once a year. There are oak branches on the ground. Basically want to leave everything pretty well mulched on the ground. I will probably remove branches over 2" but leave the branch ends to mow down. So here are several questions.
1. Does this sound like a reasonable project for a rotary mower?
2. I see adds for a couple mowers around. One is 48" and the owner said like a Country Line. My tractor is 45.6 PTO HP. I expect the 48" mower is rated for less HP. Would this damage a lower rated mower if used carefully?
3. The mowers I'm seeing are not hooked up to tractors and are older. How do I tell if they are in decent condition. One is a Bush Hog brand that looks ancient. Will try to post a photo. Bush Hog site said they have been in business since 1951 - that's 70 years ago!
Hiring a mulcher would be an awesome solution but do not want to spend the $$$.
I don't mind buying something old since it won't be used much, just want it to work decently.
Thanks!!!
   / Buying Used Rotary Mower #3
They don’t build em like they use too...
I am in similar and looking for an old Yazoo mower...
Fixed up an old one and used it one day and gobbled a lot of twigs and small brush.
The person that gave it too me saw what a good job it did wanted it back.
Neighbor on a residential hillside lot o12,000 square feet is 96 so he thought he would call a couple of the clearing guys leaving cards...
One wanted 4K and another 3k... a little steep when you live on 2500 month...
My nephew said he would help out this week...
The ban on gas trimmers is causing sticker shock.
   / Buying Used Rotary Mower #4
I bought my Bush Hog rotary about 22 years ago, and this one looks newer to me. Mine had the same design except that it didn't have the rounded rear corners. I used mine for 20 years mowing about 5 acres twice a year, and it was find when I sold it.
   / Buying Used Rotary Mower #5
Bush hog is a good brand. I would pull the fill plug on the gear box and get a look at the oil and see what shape it is in. Country line is the tractor supply brand and from my experience is cheap junk. I would much prefer to have a older bush hog in good shape than new country line.
   / Buying Used Rotary Mower #6
That Bush hog looks old and faded, but not abused.
I bought a used Woods Brushbull. It ran 30 minutes then a terrible vibration. Bearings on the output shaft had failed.
I replaced them and both seals. It has been trouble free since.
I don't think the seller knew this would happen. He put it on his tractor and ran it at PTO speed when I looked at it.
   / Buying Used Rotary Mower #7
Thanks!!!
Try to put the "County Line" idea completely out of your head!
"County Line" implements are made by Tarter Gate, under a contract with Tractor Supply.
They are the absolute low end of the 3pt. mower options.
A good brand name mower, such as Bush Hog/Frontier/Land Pride will be significantly more reliable/durable.
If the Bush Hog is pretty old would parts still be available?
   / Buying Used Rotary Mower #9
Maybe call German Bilss Parts (an online Bush Hog supplier), and ask.
1-855-667-0970
   / Buying Used Rotary Mower #10
It appears in the second photo that some alterations or cutting has been made to the top link connecting point. With the chain lying there I would suspect they are using the chain instead of a standard top link. Some folks prefer that.
24in Bucket Mini Excavator Attachment (A56857)
24in Bucket Mini...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A56859)
1990 21ft Center...
2002 International 9200i Truck (A56438)
2002 International...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
