Buttercup infestation in wheat and oats
   / Buttercup infestation in wheat and oats #1
Mearntain
Gates, NC
Ford 2000
As the title says, I've got a buttercup infestation in some of my oats and a bit of my wheat. Both have grain growing really well on them and are about a month from harvest.
Really dark green goes quickly to a light green where the buttercups are really thick at, and it's really starting to effect my crop. I wish I would have caught it sooner, but I didn't. It is going to be used for grain, hay, and and straw for hogs and other livestock I have.
Is there anything I can use this late in the process that won't negatively effect the grain for consumption?
   / Buttercup infestation in wheat and oats #2
Maybe a wiper bu you will destroy your crop where your tires run. Bummer. Just keep in mind if they go to seed and then you harvest, you just spread the buttercup to wherever you feed the grain.
   / Buttercup infestation in wheat and oats #3
wade out there and start pulling, You didn't have five strapping kids for nothing! ;-)
   / Buttercup infestation in wheat and oats #4
Is it too late to spray it out? Probably not possible to mechanically control.
   / Buttercup infestation in wheat and oats #5
http://www.cdms.net/ldat/ld0p3004.pdf
This will control it but if wheat has already jointed it will damage the crop. By the sounds you're flagleaf or later. Check label for Pre-Harvest Interval.
http://www.agrian.com/pdfs/DuPont_H...ide_with_TotalSol_Soluble_Granules_Label3.pdf
This will also work on buttercups. But same problem apply before jointing.
Sounds like you might be out of luck this year. Remember problem spots and scout early next year. Buttercup seed should be small enough that you won't get a lot of crop contamination. Will still have some, but combine should help separate.
It does sound like I'm way to late then. I appreciate the input from everyone, hopefully my yield isn't effected too much. Hopefully next year I'll be able to catch it sooner.
   / Buttercup infestation in wheat and oats #7
I used 2,4-D on buttercup problem areas of my pasture when I lived in KY. It worked pretty well.
   / Buttercup infestation in wheat and oats #8
What growth stage are you at?
An extra application of nitrogen on those spots might pay. Without seeing it I can't say for sure but with it being a lighter color it could be nitrogen deficient. That might be enough to save your yields. Also will depend on how much of the field is effected.
I'm kinda new to growing grain on this scale, so I'm not too familiar with the names of all the stages. Looking online, it looks as if I'm beyond Feekes stage 10. Most has seed on the heads already. I applied nitrogen at 120 units per acre in mud February or so.
I'll try to get some photos this afternoon when I'm back home.
Here are a few of the pics:
This is a pic of the untouched oats in good condition
Here's where the buttercups have been effecting the oats, not nearly as bad as the wheat though.
This is the stage that most of my wheat is at
Here's the seriously infected part of my wheat
This is where the wheats not as badly infected, but does still have some damage.
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
OMEGA 20 TON CRANE (A58216)
OMEGA 20 TON CRANE...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
2013 Ford Taurus SEL Sedan (A56859)
2013 Ford Taurus...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58216)
2014 AMERITRAIL...
2019 GALYEAN 150BBL STEEL (A58214)
2019 GALYEAN...
