3-Point Hitch BUSTED HOUSING
/ BUSTED HOUSING #1
ynnadresoob
bison
IHAVE A 25 HP BISON BY SHENNIU THE ROCK SHAFT HOUSING IS CRACKED DOES ANY ONE KNOW WHERE I CAN FIND ONE OR A PARTS TRACTOR FOR SALE
/ BUSTED HOUSING #2
Just to make sure we're talking about the same thing here, by "rock shaft housing" you mean the valve cover. Correct?
//greg//
/ BUSTED HOUSING
//greg//
NO THE ROCK SHAFT IS ATTACHED TO THE LIFT ARMSUNDER THE SEAT
/ BUSTED HOUSING #4
Not familiar with Shennui tractors, but if that's the hydraulic sump/lift cylinder housing you're talking about, why not just have a good welder braze it? If the Shennui is similar to my Jinma that housing is not a structural part of the frame/drive system so a good braze repair should be fine.
/ BUSTED HOUSING
IT'S BUSTED TOO BAD FOR WELD TO HOLD I SAW AN ALLIED 25 AND IT LOOKED JUST LIKE MINE I DON'T KNOW IF THE PARTS WILL INTERCHANGE I AM TALKING ABOUT THE HOUSING THAT CONTAINS THE LIFT ARM CYLINDER SOYOU ARE IN THE RIGHT AREA
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
2006 JOHN DEERE 310G BACKHOE (A65053)
2006 JOHN DEERE...
2023 Takeuchi TL6R Compact Track Loader Skid Steer w Low Hours (A63689)
2023 Takeuchi TL6R...
We Don't Dial 911 Sign (A64557)
We Don't Dial 911...
2019 GMC SAVANNAH 3500 14' BOX TRUCK (A65054)
2019 GMC SAVANNAH...
Husky 5000Watt Portable Gasoline Generator (A64553)
Husky 5000Watt...
