3-Point Hitch Busted Casting
/ Busted Casting #1
OH10
Tallmadge, Ohio
Bobcat CT235
I had an accident with my 3 point hitch and busted a casting off the Brake Case where the lower right link attaches. I tried epoxy but it didn't hold. Any recommendations? Casting 1.jpgCasting 2.jpgCasting 3.jpg
/ Busted Casting #2
I don't see that being fixed without a replacement casting.
/ Busted Casting #3
Buy new. The last cast rod I bought was 43 dollars a pound. Then grinding ,preheating and good welding . Buy new.
/ Busted Casting #6
The Kioti sight shows the housing costing a little over $300. Unless you can do it yourself the labor will be a larger cost. Axle and all has to be dropped. No matter, if you want it fixed to last I think that is your only choice. I'm not sure whether I am looking right or left? View Cart
/ Busted Casting #7
I might try mounting the broken pieces back in place (maybe using your epoxy method) then drilling through the broken pieces into the casting. Remove the broken pieces and tap the casting with the largest bolt size you can without seriously compromising the casting; I'm thinking 5/16 or 3/8 and bolting the broken pieces in place, top and bottom
/ Busted Casting
Thanks to every one for the advice. There is a local guy who has a lot of experience repairing construction equipment on-site. I'll have him take a look at it and see what he recommends. Replacing the Brake Case casting is definitely the last resort. But if it has to be . . . . .
/ Busted Casting #9
If you dont weld, I would find a competent welder and ask if he could weld it with 11018 DC low hydrogen electrode, little pre-heat first, check for seals/gaskets nearby that wont get melted by welding, that can be prevented by keeping the inner pass weld heat to a minimum, 125-300F, use a temp stick. These rods produce a very strong weld and welds fairly easy on a DC welding machine. I've repaired my big cheap Chinese made bench vise with these rods 15 years ago.
Lincoln Electrode ED3267 1118 Mr 1/8" 1 Lb. Can - Arc Welding Stick Electrodes - Amazon.com
/ Busted Casting
A young man with a Thermal Arc 3 in 1 machine came over and did a real nice job of repairing my broken casting.
Thanks for all of your comments.
Mike
/ Busted Casting #13
/ Busted Casting #14
I too hope it holds, maybe keep us informed. :thumbsup:
/ Busted Casting #15
I hope the weld holds. Welding cast steel isn't that hard just using 7018 rods as long as you get full penetration. From your photos, it really doesn't look like he used full penetration welds so durability is a little doubtful.
/ Busted Casting #16
What type of welding rods was used on the repair?
/ Busted Casting
I can't tell you all what kind of rod he used. I think it was cast steel though. I used a middle buster through a mess o' roots and it is still holding. I'll keep my fingers and toes crossed.
Mike
/ Busted Casting #18
" I'll keep my fingers and toes crossed."<<<<<<Sometimes that works when a repair is not quite 100% weld, lot of repairs tend to fail after awhile, main cause is LOF.
/ Busted Casting #19
I had the same break a couple years ago root cause was a stress fracture from the boring of the cast in manufacturing. I found an old school welder that welded it up with nickel. It wasn't cheap but is now stronger than the cast iron around it.
2018 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2018 FREIGHTLINER...
JOHN DEERE 7330 PREMIUM TRACTOR (A64280)
JOHN DEERE 7330...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
UNUSED IREV HIGH-END 2 WHEEL ELECTRIC VEHICLE (A64281)
UNUSED IREV...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
UNUSED WOLVERINE QUICK COUPLER 1 (A64281)
UNUSED WOLVERINE...
