Busted Branson
/ Busted Branson #21
Update;
Correction, the O2 sensor removal tool that I bought is by Great NECK !
This morning I plugged the lower hose heater in, primarily because I wanted to work on metal that would be at least a little bit warm.
I did other things for a while and came back to it, thinking on and off about the air in the lines, how I was going to purge them, etc.
I decided to tighten the high pressure lines "snug" and then back them off a turn, then crank it without trying to start it, I just wanted fuel up the lines and air out.
Working alone I couldn't see which, if any were leaking, so I just cranked for maybe 5 seconds and then tightened them up.
Cranked again, but it didn't start and the battery was starting to sound a bit weak.
The day still hadn't warmed up, neither had I, so I went in and did other things for another hour or so.
OK, repeat of the loosened hoses, crank, tighten hoses, crank and it started up - sounded pretty smooth too, though perhaps a bit fast.
I decided that maybe the side covers being off and me being beside it probably made it sound louder and therefore faster.
I did the trick in the manual of loosening the injector hoses at the injectors one by one. This a) confirms each injector as it quits when fuel leaks from it's line and
b) bleeds air from the line right at the injector. I think it may have got a bit smoother from this.
It certainly made me feel better about the injectors to hear each one drop the engine revs by about the same amount for 1/2 turn on the hose nut.
Then the details; air inlet manifold hose back on (quieter), side covers back on(quieter), loader back on.
Weird thing with color code sleeves around the loader hoses; red fades to pink, yellow fades to very light yellow, blue fades, but green fades to BLUE.
So raise and lower were screwed up.
I did change the fuel filter, looking back on my notes it probably has about 120 hours on it. I'm undecided, but have made note of it.
This wasn't a wasted effort, just going through pulling all the injectors and glow plugs, then getting it running again has taken me through the process.
Cleaning the electrical contacts, getting anti-seize on threads, etc all adds up.
BTW, I did discover a possible fuel pump problem. When I had the outlet hose disconnected and switched on to fill the new filter the pump did NOT run (no sound & no fuel out).
It MIGHT just be a connection, the starter switch, etc.
It comes and goes, right now it has gone.
Will see, snow is due, I will see how it starts and how it runs when totally COLD.
PS It IS worth removing the row of cylinder head bolts along the right hand side, the front 4 of them that are close to the injectors.
My Injectors weren't VERY TIGHT and I had squirted power blaster around them several times over the course of maybe 4 days before trying to loosen them.
I still felt that the O2 sensor removal tool needed to be well down and around them.
If you have a very thin wall 22mm socket it might not matter.
/ Busted Branson #22
Reg,
Really appreciate your time inputting your injector experience. I know it's just a matter of time before most of us will live the same dream. I've had a 65 Massey gas engine for 20+ years, my 4720i is my first diesel tractor and am sure good times are in my future too. But I sure do like diesel power, unbelievable difference compared to gas. My service manual reads the same as yours......don't spin the injector or your damage the head, just grab an old 22mm box end wrench and an adjustable and there literally spin right out in your hand......yeah right. What model is your branson?
Thanks again,
/ Busted Branson #23
Y'welcome.
SOME of my motivation was to show that it isn't THAT MUCH harder than taking out spark plugs.
Different, yes, but not much harder.
This was on a 42 horse "Cummins" (designed. Kukje built) engine.
There really is NO keyway in the head and no key on the injector bodies.
I am NOT recommending to anyone that they just take a 22mm wrench and have at it.
There may well be (probably is) a model with head and injectors exactly as described, just not mine and you are right to ask me which model.
The thing about the "Shop manual" is that it seems to have been translated from a Cummins generic book to (I don't know what language) and then back again to English, but it is pidgin and some words are nonsense until/unless you read them out loud.
Then it is charades "Sounds like" ______ Oh, gottit "Hold Down Nut"
I have little/no confidence in the diesel specialist that I took the injectors to.
Too bad, since two shops recommended them to me.
It might be that they really don't like "amateurs off the street" walking in there for free tests ?
/ Busted Branson #24
I just stumbled onto this thread, but hard to start? engine damage? sounds like a little to much ether?......
2011 Kenworth T400 33Yd. Side Loader Garbage Truck (A64194)
2011 Kenworth T400...
2007 Yamaha Rhino 4x4 Side by Side Gas Cart (A64194)
2007 Yamaha Rhino...
2001 Freightliner FL112 T/A 5 Car Hauler Truck (A64194)
2001 Freightliner...
1987 Polar 307 SS 3 Comp SS Insulated T/A Chemical Tanker Trailer (A64194)
1987 Polar 307 SS...
2013 Buick Verano Sedan (A64557)
2013 Buick Verano...
2013 Kubota BX2370 44in 4x4 Compact Utility Tractor Mower (A61572)
2013 Kubota BX2370...
