Bushhog RDTH72 Finish Mower Spindle
/ Bushhog RDTH72 Finish Mower Spindle #1
5133
Ohio
New Holland TC40
Good evening. I have a 20 year old Bushhog RDTH72 Finish Mower and am working to rebuild the spindles. I've never done this before and I watched several YouTube videos but none were really like my spindles I have. I have several questions.
1. After I remove the snap rings on the spindles how is the best way to remove the shafts. I beat and banged on mine and got it out, but the lower bearing is still attached to the shafts. How do I get that off the shaft?
2. When removing the shaft I damaged the pulley nut threads. My fault for cavemanning it. How is best way to protect those threads?
3.I was able to knock out the upper bearing with bearing driver.
I apologize in advance for what many will think as simple, but I'm learning here. My normal teacher, my Dad, is no longer able to help me unfortunately. Thanks in advance.
/ Bushhog RDTH72 Finish Mower Spindle #2
Welcome to TBN!
Put a sleeve over the threads that seats on the shoulder just below the threads. Another way is to thread the nut back onto the shaft, upsidedown if a castle nut, until flush with the end of the spindle. You can still damage the threads this way if you beat on it enough.
A little heat on the shaft by the bearing may loosen it up to be able to drive the shaft off of it.
My dad was a good teacher too, but alas, he is no longer with us either.
Welcome to TBN!
TractorTech,
Thanks so much for the guidance. I really appreciate it!
/ Bushhog RDTH72 Finish Mower Spindle #6
Let us know how it turns out!!! I have the same mower and dumbfounded that my spindles haven't given out!!! Also 20 years old when I bought it used!!!
1995 Jeep Wrangler 4x4 SUV (A59231)
1995 Jeep Wrangler...
UNUSED IRANCH MINI EXCAVATOR RAKE (A60432)
UNUSED IRANCH MINI...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
Deere 50D (A60462)
Deere 50D (A60462)
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
UNUSED KJ K4525-45'X25' DOUBLE GARAGE STEEL BARN (A60432)
UNUSED KJ...
