Rotary Cutter Bush hog
/ Bush hog #1
keppy
Kinston,NC
B7510
I would appreciate any help on this.
I have a B7510 Kubota tractor and I bought a used King Kutter 48". My problem is that the mounting pins on the A frame are so high I have to raise my 3pt about 75% up to hook it up. I have to angle the deck so much with the top link just to get the wheel high enough to get it on the trailer. My question is can I drill lower holes to lower the hitch pins or would this lower the ability for my tractor to pick it up and damage my hydraulics ?
/ Bush hog #2
Won't have any negative impact on the tractor's ability to pick it up and/or damage hydraulics.
Might want to park the tractor backed up to the cutter but far enough forward so the 3pt arms can be lowered all the way. This will let you decide where to relocate the holes without getting them too low. Too low and you won't be able to go over any kind of hump without the cutter raising, even with the 3pt all the way down.
If the design of the cutter framework allows you to move the holes I see no reason not to.
/ Bush hog #3
Ooppss, forgot to mention, after moving them be very considerate of the PTO shaft!!!! You may create a situation where you raise the cutter so high the PTO shaft makes contact with the front of the cutter platform. Not good.
/ Bush hog #4
I had exactly the same problem with my John Deere 2720 and Frontier 2060. My hitch had a second pair of hitch pin holes that were slightly lower and further back. When I moved the pins to the lower holes I was able to lift the cutters wheel about knee high. Where before, I could barely get the wheel off the ground.
/ Bush hog
Thanks for the help guys. The holes are 13" now. I think I will lower them to 9"
/ Bush hog #6
FYI, my lower hole is 3" lower and 1.5" further back from the top hole.
/ Bush hog #7
Make sure it doesn't affect the length of the pto shaft when lifting it. Changing the the height will affect the shaft angle and might affect the length the shaft slides. If the shaft slide bottoms out you could damage the pto housing and guts. If its too long you can cut the shaft a bit.
/ Bush hog #8
I had the same issue with my King Kutter 6' on my tractor.
Drilled new holes and lowered the pins 2 or 3 inches (can't remember how far), no issues.
Watch you don't lower the pins to far where the PTO shaft hits the deck when lifted.
Rightline LP5C-C5B0-A 42in Hydraulic Side Shift Forks and Frame Forklift Attachment (A61572)
Rightline...
2025 Fabrique 12' x 6' Dump Trailer (A62613)
2025 Fabrique 12'...
2014 MERCEDES 2500 CARGO VAN (A59911)
2014 MERCEDES 2500...
2025 GIYI GY-P45 Hydraulic Breaker Skid Steer Attachment (A61572)
2025 GIYI GY-P45...
2012 INTERNATIONAL LA677 4X2 S/A DAY CAB TRUCK (A59911)
2012 INTERNATIONAL...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
