bush hog wheel question
/ bush hog wheel question #1
varmint
Elite Member
Northern Maryland
Kubota B8200, then a Kubota L3130 HST, now a Kubota L3400 HST
Bought an old, but good, 4' bush hog. Works great, except the tail wheel drags sideways when going forward, which is not great. Curiously, it tracks well going backwards. I am quessing it needs a little more rake, and I am considering cutting a deep notch in each side, bending it back about 3/4" of an inch, and re-welding. Any advice??
/ bush hog wheel question #3
Mine was doing something similar. The wheel axle bushings had gone bad allowing the wheel to wobble. Bought a new one at TSC, had to shim it with a couple of washers but it goes straight now.
I cut out wedges from the forks, beveled the cut's edges, bent the forks together, and welded them. I think this solves my problem.
/ bush hog wheel question #6
Looks good
Please post how it works and I am adding tailwheels to flail mower and I need to ensure it has the right amount of rake/caster.
I will report, but it'll be a while. I just looked at "better" rough cut mowers, and tried to more or less match their offset rakes, without creating any issues for myself, like the wheel hitting the frame. I have no idea what brand this was, but the welding precision was awful- whoever put it together did a lousy job of aligning things up and centering stuff. Hopefully, next fall when I use it again, it will track properly. I may just test it when the ground is dry- we'll see.
2017 CATERPILLAR 249D SKID STEER (A65056)
2017 CATERPILLAR...
INDUSTRIAL HOSES (A68842)
INDUSTRIAL HOSES...
2020 MITSUBISHI FE160 4X2 S/A 20FT BOX TRUCK (A69168)
2020 MITSUBISHI...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
PORTA POTTY (A68842)
2011 MAGNUM TRAILER LIGHT PLANT (A67714)
2011 MAGNUM...
