it's my standard flush for wet sumps
1 of the following ( diesel, kero, mineral spirits ) + 90% rubbing alcohol + Type f or dex/mer3 atf.
you get petro solvents thin the mix to move easier, and may remove stuck and clumped emmulsion, detergents from the atf ( suspend gunk to be carried out), and a polar solvent (alcohol ) to disolve water and carry it in soloution with the oil and petrosolvent mix.
As a side bonus, since the alcohol is a polar solvent, any water and alcohol mix left in the sump from draining will be in the form of an azeotrope, and thus will flash off faster that water by itself.. thus heat from working the box will flash off remaining disolved moister faster than without the alcohol addition.
Could even add an ounce of alcohol to the new oil as a prophylactic to grab incomming moisture.
