Rotary Cutter bush hog gearbox rating & sheer pin vs. clutch
   / bush hog gearbox rating & sheer pin vs. clutch #1
witterbound
I'm a greenhorn, and looking to buy a bush hog. I've got two questions. What does the gear box rating mean. I see some are 40 hp and others are 60 hp. Does that mean my tractor pto hp shouldn't exceed those gear box hp ratings? Second, is a slip clutch worth the extra money? I'll be cutting mostly pastures. Thanks for all the help you're giving me!
   / bush hog gearbox rating & sheer pin vs. clutch #2
yes a slip clutch is worth the extra money, without a doubt.
   / bush hog gearbox rating & sheer pin vs. clutch #3
1. 40 and 60 are the small boys. They go up considerably from there. But to the point, it's a number that relates to your tractor's PTO horsepower rating. If you're rated for 45hp at the PTO, don't buy a mower with a 40hp transmission.
2. Yes, but again it's dependent upon the horsepower rating. They're not as common on the low end implements.
//greg//
   / bush hog gearbox rating & sheer pin vs. clutch #4
The slip clutch is a great thing - but requires steady mainenance. If you don't want to spend the extra 15-20 minutes every time you use use it, then save the bucks and just get the shear bolt.
A slip clutch will freeze up in as little as a day if left in a moist area, or in 1-4 weeks in a typical barn environment. The only way to know if it is free or not, is to loosen the bolts and slip it, the tighten them back correctly. A shear bolt is a hook up and go deal - until you pop them. If you are just doing a pasture, you probably won't pop more than a half dozen bolts in 10 years.
jb
   / bush hog gearbox rating & sheer pin vs. clutch #5
I agree.. if you don't maintain it religously.. get a shear bolt design..
soundguy
   / bush hog gearbox rating & sheer pin vs. clutch #6
http://www.landpride.com/ari/attach/lp/public/manuals/311-254m.pdf
Start at Page 17...you'll find discussions on both 4 bolt and 8 bolt slip clutches...:)
   / bush hog gearbox rating & sheer pin vs. clutch #7
Well I'm definitely working on exceeding a few shear bolts in 10 years:D . I've gone through 3 in the last 3 weeks as I've been clearing some cactus and trying to avoid rocks. Seems my 6' frontier has a lot of iniritial (sp) weight and I need to be very carful when going over some of the vegitation on the property. I'm looking at adding a slip clutch because of the number of shear pins I'm going through and a $3.50 a pop it's going to get expensive.
In Arkansas, I'll likely be hitting a lot of rocks, as they seem to grow in some areas I'll likley be bush hogging. If I hit a rock am I likely to shear a pin, or will the bush hog blades flex enough to save the pin? I though that the "unfixed" blades on a bush hog kept it from binding up like mowers can. Is that wrong, or are the unfixed blades just one defense, the sheer pin being or clutch being the backup?
   / bush hog gearbox rating & sheer pin vs. clutch #9
Maybe I got a good one, because I haven't found that to be true. I used to disassemble/clean/reassemble/adjust mine twice a year. Skipped one of them a couple years ago, so the thing went a year without maintenance. Still worked fine. Even though mine's parked out in the pasture year round, I've had no problems at all cutting the maintenance back to once a year.
//greg//
   / bush hog gearbox rating & sheer pin vs. clutch #10
witterbound said:
... will the bush hog blades flex enough to save the pin?
Ain't no flex to a rotary cutter blade - they're your basic blunt instrument, usually an inch or more thick. I too had a shear bolt rig before I went slip clutch. Never broke a shear bolt till I hit a horse blanket. The RC would hammer away at 50 pound rocks without batting an eye. But hit a horse blanket......!!! Fence wire will do it too.
//greg//
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
2007 JLG SkyTrak 10042 10,000lb 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
Spool 16mm Wire Rope (A47384)
Spool 16mm Wire...
1985 Chevy C8500 Auger/Derrick Truck (A50323)
1985 Chevy C8500...
