bush hog chain or solid bar?
/ bush hog chain or solid bar? #1
horses2
Westminster, Md
Kubota M471D
I replaced my old bushog with another preowned unit. the one I had used a solid bar to the tailwheel from the A frame. the unit I have now has a chain.
So, what are the advantages and disadvantage of each? it appears the newer models are all "solid" mounted with a frame piece to the rear of the mower.Should I change the chain over to a bar or solid piece?
Also, this unit is apparently a Ford unit made by Bushhog. it has Ford emblems/decals on the deck and has a bushhog model/serial number plate rivited to the deck. the model appears to be S050R, not sure if its a 0 or O.
any help with id for replacement blades? the ones on thier now are about 24.5" overall length, cutting edge 9.25", width 3", offset looks to be about 2".
thanks,
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
Heavy Duty Fork Extensions (A65640)
Heavy Duty Fork...
2019 Freightliner 122SD (A62679)
2019 Freightliner...
Mower King SSRC (A64127)
Mower King SSRC...
Asphalt Melter (A61572)
Asphalt Melter...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
