bush hog chain or solid bar?
/ bush hog chain or solid bar? #1
horses2
Bronze Member
Westminster, Md
Kubota M471D
I replaced my old bushog with another preowned unit. the one I had used a solid bar to the tailwheel from the A frame. the unit I have now has a chain.
So, what are the advantages and disadvantage of each? it appears the newer models are all "solid" mounted with a frame piece to the rear of the mower.Should I change the chain over to a bar or solid piece?
Also, this unit is apparently a Ford unit made by Bushhog. it has Ford emblems/decals on the deck and has a bushhog model/serial number plate rivited to the deck. the model appears to be S050R, not sure if its a 0 or O.
any help with id for replacement blades? the ones on thier now are about 24.5" overall length, cutting edge 9.25", width 3", offset looks to be about 2".
thanks,
210 Gallon Plastic Tank with Pump (A65640)
210 Gallon Plastic...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
6 1/4 INCH OD 90 DEGREE ELBOWS (A65643)
6 1/4 INCH OD 90...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2024 Ford Explorer SUV (A61574)
2024 Ford Explorer...
2017 Cat 316FL Excavator (A62679)
2017 Cat 316FL...
