Corn Head grease (0wt) may be a better option. It was made for gear boxes.That or fill the gearbox with grease, it will run forever.
Just went to this oil this year in the BH brand BH and the Flail. Hoping it makes everything last longer.Corn Head grease (0wt) may be a better option. It was made for gear boxes.
I have an 8' Bush Hog withe a central gear box and one on either side that drive the blades.That or fill the gearbox with grease, it will run forever.
It will work everytime.I have an 8' Bush Hog withe a central gear box and one on either side that drive the blades.
Few years ago the right hand side one started to leak so much gear oil I couldn't keep up.
I packed it with old grease I had.
No problem.
If yours isn't leaking 90 gear oil is good.
They leak so much refilling them changes the oils annuallyYou all change the oil in your gear boxes?
