Bush Hog Blade Replacement_Frozen Bolt
   / Bush Hog Blade Replacement_Frozen Bolt #1
jpetropoulos
groton ma
Kubota L35
Hi All
I have a Bush Hog SQ600 with a broken blade. I am accessing the blade retaining nut from the top of the deck and even with a 5' breaker bar on a 3/4" drive socket I am unable to move the thing. I have tried penetrating oil and heat. Am I missing something?
Thanks
   / Bush Hog Blade Replacement_Frozen Bolt #2
I would say "yes".
Torch out BOTH bolts, replace both blades, nuts and bolts and get on with life. Don't waste time generating aggravation. If you don't have a fire wrench, chop out the nuts and replace both blades and nuts and bolts. Maybe try adding a pipe extention to the breaker bar and snap the bolts out.
DONE.
   / Bush Hog Blade Replacement_Frozen Bolt #3
Have you tried a pneumatic impact wrench? I have an SQ600 and that's what I have used.
Sent from my iPad using TractorByNet
   / Bush Hog Blade Replacement_Frozen Bolt #4
Hi All
Thanks
About another 5' extension on that breaker bar. Its not unusual to require 1000ft# or more to loosen a bolt thats been there a while.The ones on my bushog I tighten to 600#+ anyway.
   / Bush Hog Blade Replacement_Frozen Bolt #5
IF you resort to cutting them out, if you can get the center stump jumper nut off, you can access the blade bolts/nuts lots easier to either torch or grind them off.
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2001 CHEVROLET TOW TRUCK (A52472)
2001 CHEVROLET TOW...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A51572)
2007 Isuzu FTR...
2021 John Deere 5045E  Only 86 Hours, Loader Ready, 2WD, Canopy (A52748)
2021 John Deere...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
