Bush Hog BH25 yokes breaking
/ Bush Hog BH25 yokes breaking #41
I see torch marks on the back end of that toggle/flex link and there shouldn't be any. Has it been shortened enough so it aligns with the failing bars? If they are aligned and parallel in tension the link won't work as designed in compression.
The fore/aft centerline of that flex link needs to be at a lesser angle from horizontal than the center line of the black bars.
Not so sure those are torch marks (?) That part of the flex link is meant to be limited in downward travel in order to prevent a fold "under" instead of fold over the pivot bolt. The ragged edge may be the result of banging on the bolt ?
/ Bush Hog BH25 yokes breaking #42
I still think the problem is coming from backing into stuff and forcing the cutter up with too much force.
Looking at pictures of the original set up of the BH25 I think the two bars are not the same.
The "bend" in the bars is much closer to the rear mounting tabs in the pictures of a new one.
The bend in the bars on his is much further toward the front of the cutter. You can see in the picture that it seem to contact the rear mounting tab at a bit of an angle which could create a binding point.
ing point.
/ Bush Hog BH25 yokes breaking #43
The paint is burnt on the edge. The end has obviously been flame cut. The bolt that the part strikes against would make a small mark on it. There would be no contact along the entire end. There is nothing there for the entire edge to hit.
The link is obviously not designed to fold under. It is also not designed to be parallel with the failing bars.
Rough ground or unique operating conditions can also demand more travel than the flex link can provide. Replacing the bars with chain is still an excellent alternative.
/ Bush Hog BH25 yokes breaking #44
Wirlybird -- I agree for sure. That is the only mode in which I broke mine and I bet that's how all of them get broken -- backing too hard into something creating unpredictable upward motions. Great catch on noticing that 'kink' being down much closer to the rear attach points (yellow arrow) on the newer hogs ! I believe the 'natural' bending or kink point for failure mode is about mid length of those straps making that a poor place to put the manufactured kinks. That may well be why the newer ones are near the rear attach points.
/ Bush Hog BH25 yokes breaking #45
You may be right, Rick. I saw what I thought was rotational wear and you saw it as burned paint. Your strongest evidence is the ragged edge which would tend toward a torch cut. But the whole clevis or flex link does not seem to be any shorter (based on the bolt positions in brand new machine pictures) so that is a puzzle if it was torch cut.
The more I look at the large pictures of the problem rig the more it looks to me like the whole thing was "in a wreck" of some sort. Notice that the right side strap up in/near the flex link/clevis is twisted from the vertical? How do you even do that ? I'm thinking that happened at the moment of the harsh rear end collision with a tree or boulder or whatever. When you back too hard into some obstacle the hog raises up under terrific stress goes into a twisting motion (counterclockwise when viewed facing forward) which snaps the left strap and leaves the right one twisted as the picture shows it. AND I'm with Bush Hog and the dealer saying "Nope, we don't cover that behavior and that result." Actually I could see this damage potentially having happened from the tractor running away backwards down a hill ending in a collision of the hog with some immovable object. NOT saying it did ...
p.s.: Rick, I think that the most forward bolt in the flex link/clevis (one that says YfS on the bolt head) is in a slotted hole in the black center metal. Thus repeated (errant) contact between the red parts you see as having been torch cut can be all along those red metal edges for a distance equal to the length of the slot in the black center metal. If so it was a lot of times ... more sign of abuse, if that was the case.
/ Bush Hog BH25 yokes breaking #46
Additionally the flex link is supposed to be a welded assembly. In the pics it appears to be two separate pieces that can move independently. That's not at all helpful.
  • Good Post
Reactions: JWR
There are no torch marks. Nothing has been modified or shortened. When that link is in the resting position, everything is in direct alignment. When upward pressure is applied to the tail wheel the ramp is forced upward by the rear bolt that has a bushing on it.
It's as it should be. There is some wear on that ramp but it's not affecting anything.
The pivot link allows only so much travel. Is he backing up to steep banks or something similar that would bottom out the link? Or operating with the link already well into its travel?
Even with the link bottomed out the 3pt should allow the deck to get pushed up. So there shouldn't be that much force through the bars, just some fraction of the weight of the mower. Clearly that's too much for that bend but it should be ok with some reinforcement.
Nothing steep.... there are a couple swails but nothing real steep.
Parts fische shows it as two separate parts not welded together. I have seen some that are welded but this one is not.
  • Good Post
Reactions: JWR
NOTHING HAS BEEN CUT WITH TORCH.
What you are seeing as twisted is not. The broken bar on the left side is letting the yoke sag and making appearing to be twisted. It's not.
This guy doesn't abuse anything. In fact, pretty much everything I've been repairing for him is just because the equipment is sitting around unused. He was a test pilot for Lockheed back in the day and everything is strictly by the book. If the manual says don't exceed 2500rpm, he won't go over 2400rpm.
/ Bush Hog BH25 yokes breaking #51
OK. You are there, I'm not. I don't think reinforcing those bars is the answer, but again, it's not my machine and I'm not there. While you have the welder out, weld those flex link halves together.
And this is what is being mowed.
As I said before, was looking to see if anybody had problems with these bars being compromised before being put into service.
  • Good Post
Reactions: JWR
/ Bush Hog BH25 yokes breaking #53
So this picture you provided
on the red link above, it looks like part is broken to the right.
If that part had another bolt hole for the black link to bolt through, then there would be zero flex in the system, so I'm ruling that out.
Instead, that part was longer to block the flex motion (keeping the black link below the red link) causing the black link's rotation upwards to force the red link upwards as well.
Now, with the part broken like that, the black link may be able to flex upwards enough, such that the black link is in line with the red link, whereupon there would be no tendency for the red link to rotate, and instead all of the force of the upward riding cutter would go straight through the links to the attaching bolts, and something gives.
If you'll excuse poorly-drawn scrawl on paper I've tried to illustrate this:
If the red link was better lubed, the red link may continue rotating with the black link and nothing bad may happen, but if the red link doesn't readily move then the black link more easily "catches up" with the red link and comes in line with it, causing the linear compression.
In fact I just found a picture from this manual :
Here you can see that the black links on the mower in question (orange & leading to the lower left in this pic) are supposed to be inside that upper link, and that upper link is supposed to be longer and have a bolt through... which will do what I described above.
Some of the pictures in that manual show the main triangle having 3 bolt holes; if this one's got 3, the flex link should be in the middle hole to allow more flexion.
Fix the flex link, and it'll work within a reasonable range of motion.
Or, leave it how it is, and use chains instead of the black links.
Either way, I'm with BH and the dealer on this one; operator error (in this case, a failed fix) caused those arms to break.
/ Bush Hog BH25 yokes breaking #54
Ah, I see what you are saying. The two bolts are not parallel which is because the left strap in broken and hanging lower than the right ... which is also why the left half of the flex link/clevis is lower as well.
Appreciate the positive feedback on the owner and, while I sensed a wreck of some sort, I did not mean to say he was necessarily that hard on his equipment.
/ Bush Hog BH25 yokes breaking #55
I see now that that same manual shows other pictures which are pretty similar to his pictures.
I'm standing by the assertion that the two links (black & the supposedly flexing orange yoke) are coming into line and causing a compression that's making the break. I guess that what looks like a break in the yoke is just wear & tear?
It just looks like a bad design now. Leaving my other post up just because...
/ Bush Hog BH25 yokes breaking #56
Ning -- lots of good effort to explain but I disagree in a couple of places. First the photos you show from a manual or wherever are NOT of a BH25, that is some less heavy duty hog. Current pics of the BH25 do show the flex link/clevis halves on the inside and the straps on the outside just as the OP shows. I see you caught that too by your post #55. Second the OP will have to confirm but I do NOT see anything broken about the flex link/clevis. Some wear yes, broken no.
Also my studying of that linkage says there is no possibility of the black and red metal coming into straight alignment for compression. Take all cases into account and realizing the front one of the two relevant bolts is in a slot in the black metal, not a hole. Incremental movement tending toward compression from any position causes upward movement of the joint and prevents 'hard' compression. Not a faulty design there.
To the OP: Beautiful fields. Rarely do I get to bush hog on that nice a land/scene. Nothing there looks like trouble for rotary cutting.
/ Bush Hog BH25 yokes breaking #57
Here is something to possibly look at. See the wear spot indicated by the arrow.
Could it be that the leading edge of the black bars are moving forward in the slot on the red part and binding at the front were the arrow points and not allowing the red part to pivot up?
I think I would get the tractor and cutter on to solid level ground with the 3-point lowered all the way as if cutting and then place a jack under the tail wheel boom and start to jack it up and see how the whole assembly works and pivots. See how far the rear wheel will go up before it runs out of travel and see if the bars start to bend outward.
/ Bush Hog BH25 yokes breaking #58
I think with extension, it could come into line, and then subsequent reversal could potentially cause the compression. If the other links are stiff, more easily than otherwise, and it won't necessarily happen every time. With more wear, though, the extension could result in a locked joint which would increase the chance of the compression.
If the flex yoke can't rotate downwards from its current position, I agree with you that extension causing the links to line up won't happen.
If you look at the wear inside of the black links, it does look like the red yoke is getting all the way in there at least occasionally.
Also note that it looks like the end of the red yoke is worn by impact with something - probably that angle is in place there intended to deflect the yoke upwards in case of a linear bind, but as that wear occurs, more and more strain is sent through the links briefly during the bind-up, and at some point there may be no more deflection from this angle and instead all of the strain may be going through the bolt on the left if the bolt on the right isn't hitting that ramp.
(apologies for lousy annotations but my screenshot extension doesn't have other colors)
  • Good Post
Reactions: JWR
/ Bush Hog BH25 yokes breaking #59
Here is an actual picture from the manual showing the bends in the yoke straps. You can see how far back the bends are.
I think the straps on it are incorrect.
I would also check that the top link is getting set correctly as instructed in the manual.
Looks like part # 50050342
Except I just unwrapped then new parts and helped him install them ..... new parts had a tag with that exact part number. I double checked.
Adams Under Truck Conveyor (A61307)
Adams Under Truck...
2013 Freightliner Bucket Truck (A55973)
2013 Freightliner...
2017 Ford F-650 Mason Dump Truck (A59230)
2017 Ford F-650...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A61306)
Bulk Lot of NEW...
PALADIN HP750 ASPHALT PLANER (A60429)
PALADIN HP750...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A60430)
2019 CUSHMAN...
