bush hog 2510
/ bush hog 2510 #1
tazzer
omaha tx
ford 2120
ok anyone happen to know where I can get a rubber element joint for my 2510 without paying out a arm and leg for it ?
the part is 868.00 plus the u-joint will make over 900.00.
maybe a way to replace them with a friction clutch or something that will work as a replacement that wont cost a ton or should just bite the bullet and buy it.
I replaced the other one last year.
/ bush hog 2510 #2
I have a John Deere 660 rototiller. I broke the slip clutch and John Deere wanted just a bit too much for replacement parts. I went to local farm supply store and they were able to supply me with a replacement slip clutch at about half the price of the Deere one. I took the old clutch in and they measured it to determine which replacement size to order. I can't remove the PTO shaft from the rototiller the way I could with the Deere slip clutch but I don't really need to remove the PTO shaft from the rototiller on a regular basis so all is good.
2018 Dodge Charger Sedan (A64557)
2018 Dodge Charger...
1991 Ford F600 Fuel Truck, VIN # 1FDNK64P0MVA37029 (A65563)
1991 Ford F600...
Michelin Mach X BIB 710/70R42 Tires (A65640)
Michelin Mach X...
2015 Ram 4500 Service Truck, VIN # 3C7WRKAJ9FG707673 (A65563)
2015 Ram 4500...
John Deere 772-A Grader (A62679)
John Deere 772-A...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
