Burying wire and irrigation lines
   / Burying wire and irrigation lines #1
rush389
Bronze Member
1949 Oliver 77
I just pulled the trigger on a new 3025e and one of my first projects will be burying the wire for an invisible dog fence. I only need to get an inch or so of dirt on top of the wire.
Also, eventually I would like to run some additional 1 inch irrigation lines to feed a dripper system.
My best guess is that a subsoiler like this is my best bet:
3 Point Subsoiler-Subsoiler Attachment | Agri Supply #7341
Am I on the right track?
   / Burying wire and irrigation lines #2
It will handle the dog fence wire. I don't know about the 1" irrigation line. It will have to be a poly and not PVC line. Your tractor weighs about 2000# so you're not going to get very deep with the pipe. It takes a lot of weight and some power for anything that moves thru the dirt.
ok thanks. yeah, i was thinking the poly.
   / Burying wire and irrigation lines #5
I don't know what you guys call it on your side of the pond but our normal underground water pipe, what we call "blue alkathene" is pretty resistant to frost damage. I wouldn't worry at all about laying it where it might freeze, so long as you don't need to used it at that time. In fact the pipework inside our open barn freezes every winter. The only real issue is movement, make sure it won't push or pull a fitting off when the temperature changes.
The colours and uses of MDPE explained | JDP
   / Burying wire and irrigation lines #6
I do not know where you live, the type of soil or how deep you need to bury the 1 inch. I used to work for a company that buried underground hard telephone cable back in the day and that took serious power but we went pretty deep. Can the company advise what HP/weight etc. you would need?
for the dog wire, i just want to create a little pocket so it doesn’t get cut by the bush hog. probably going to encircle two acres or so.
for the pipe, i am not too worried about freezing. we have a bunch of that black poly stuff everywhere, i just want to add more. right now we have some drip lines on the hose spigot on the house, and i have to disconnect every time i mow the grass. i just want to run some pipe to tie those drip lines into the rest of our irrigation system.
   / Burying wire and irrigation lines #8
As i7Win said an edger will give you a slot to install the dog fence. You could use the trencher too but too deep it may not be as effective.
If you get the trencher you will need the pipe option too Single Tine Ripper 3-Point Pipelayer Attachment | Agri Supply 73622
It will work reasonably well if you don't have a lot of bony/rocky soil probably get you to 4-6" deep with pipe. Its a two person job.
   / Burying wire and irrigation lines #9
I used a single bottom plow to put in wire for an invisible fence with my old sears tractor. It dug down 4-5 inches with out too much trouble. Roots were the biggest issue for me. Did the same for my Dad's satellite dish (different tractor and 14 inch plow), but we did have to deepen it some by hand. Around here, low voltage doesn't have a depth requirement, and power needs to be at least a foot. When we were done, we just rolled the furrow back, pretty clean.
I can't speak to pipe, but it's worked out for me with wire.
If you've got tough ground, it may not work as well.
   / Burying wire and irrigation lines #10
Careful where you mount the charger for the dog wire. The wire tends to be a lightening magnet.
I tried the invisible fencing once and didn't have it in the ground two weeks before I had a lightening strike. It blew the controller off the wall in my garage and blew the GFI outlet it was plugged into out of the wall.
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A52748)
2022 NEW HOLLAND...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
STORAGE FEES (A52576)
2012 FORD F-250 XL SUPER DUTY (A52472)
2012 FORD F-250 XL...
AIRMAN POS100S PORTABLE AIR COMPRESSOR (A52472)
AIRMAN POS100S...
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A51692)
2013 International...
