Burnt off some turkey
/ Burnt off some turkey #1
Steve_Miller
Nova Scotia, Canada
2006 Kioti CK30HST
Finally got to some of the projects with the ten days off. First was my aerator, not quite finished just have to put some wheels on for transporting around.
another view
A stand for my new backblade
My toothbar I built, I bought the teeth on ebay. They are the pin on type.
Steve
/ Burnt off some turkey #5
Nice tooth bar!
How about a link to the teeth and the shanks?
/ Burnt off some turkey #6
On that toothbar photo, looks like you already chased down the dog and stuck him with the right side.
Looks good eh.
/ Burnt off some turkey #7
Steve
Great job on both. What did you use for the teeth on the aerator? Are they hardened or just mild steel. I could use one here but I have a lot (read everwhere /forums/images/graemlins/mad.gif) of stones and I think I would spend most of my time bending them back or rewelding them back on.
Great Toothbar. Looks as good as you could buy and you have the pleasure of knowing the builder if something goes wrong.
Al
/ Burnt off some turkey #8
Nice projects, and looks like you did a great job! Man, I wish I could weld like that.
<font color="red"> Chris,</font> I found them by fluke one day, the guy doesn't list that much but I happen to come across them, I think his ebay company name was Getdirect and his handle was 'getpdq'.
<font color="red"> Al, </font> The teeth are just mild steel, I cut them out of 3/8" flat bar 2 1/2" wide at a 30 degree angle. For all the aerating I'm going to do I didn't need the hassle of trying to cut that many from hard plate. My soil is almost useless here and I wanted something to aerate then be able to fertilize.
<font color="red"> Chuck, </font> Didn't you notice that I specifically doidn't take close ups. /forums/images/graemlins/grin.gif My welding is not as good as you might think. I could take some close ups if it would make any other rookie welders feel better. /forums/images/graemlins/confused.gif
<font color="red"> Joe, </font> The so called blood is chev orange paint I used to paint the stand I made for the backblade. I do have a dog that on the way out though. She has one lung that is completely taken over by a tumor. She can still get up and walk around but has no wind at all. She's held on for almost a year now, but is starting to noticeably fade. I pains me think about the day that is coming.
Happy New Year to all
Steve
It was a piece of 10" schedule 80 black iron pipe kicking around at work.
Steve
/ Burnt off some turkey #12
Curious how you made your stub shafts.
Only way I've seen is to machine two round disks that will slip fit in the tube. Then drill or burn holes in the tube so the inner disk can be plug welded. The outter disk is welded around the circumference.
The shaft is welded to the two disks first.
Anyone got an easier (less machining way) to accomplish this?
THANKS.
Ron
<font color="orange"> Only way I've seen is to machine two round disks that will slip fit in the tube. </font>
Ron, thats exactly right, machine shop where I work is always very accomodating. I wanted them water tight as I drilled a 3/4" hole in one end to be able to fill with water for weight.
Steve
/ Burnt off some turkey #14
what is that, a soil compactor?? /forums/images/graemlins/smile.gif
Finally got to use the aeorator today. This pic was on grass that is rooted fairly well.
This was on an area that the grass is not very dense yet.
This is a finished view of the beast.
Steve
/ Burnt off some turkey #18
A mighty fine job your doing there.
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
1992 GMC Top Kick Fuel Truck (A62679)
1992 GMC Top Kick...
2021 ASV RT-120 FORESTRY SKID STEER (A65053)
2021 ASV RT-120...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
2016 Ford F-550 Service/Mechanic Truck with Crane, VIN # 1FDUF5GTXGEC76689 (A65563)
2016 Ford F-550...
