Burned out pump?
/ Burned out pump? #1
YukonKing
Whitehorse Yukon Canada
2021 L2501 FEL
Little Help?
Ok So, Jinma 254LE main tractor pump/gear type. So I started her up on boxing day and let the tractor warm up. However I put her on high idle fairly soon (cold oil). When I came to move the tractor 1/2 hour later there were no hydraulics nothing. The pump was hot to the touch, starved for oil? So I took it apart it all looks ok?
thoughts
/ Burned out pump? #2
You have a classic case of water in the oil. Ice is blocking the flow of hydraulic fluid to the pump. You should mic the clearances to determine the wear. That 1/2 hour with no lubrication is like 1000 to 5000 hours of normal operation.
/ Burned out pump? #4
Post the specs from the book, then the observed clearances.
Also.. find your blockage.. sometimes QD's get cocked apart and won't pass oil.. Jinma tractors have a bad habit of placing QD's in line with pumps... Kinda of a 'designed to fail' sort of situation... Like putting you in the center of a 3ac mine field with only one safe path out.. oh yeah.. and you are blindfolded!
soundguy
/ Burned out pump? #5
Can you separate the side plates from the gears and send pictures of the sides (ends) of the gears and the inside surface of the side plates? I suspect the most scoring occurred where the sides of the gears rub on the side plates. I also suspect the plain bearings in each side plate for the end of each shaft scored. If the side plates are stuck on the gear shafts, that is a pretty good sign that the bearings are scored. I am surprised that the pump did not seize and shear the key in the input shaft.
/ Burned out pump? #6
You can't troubleshoot the internals of a pump with pics over the internet. Heck, without micrometers, I can't do it with the pump in my hand.
