Burned JohnDeere 4100
   / Burned JohnDeere 4100 #31
I have to agree that rehabing is probably not worth it, but the experiance and knowledge gained from taking it apart could be great. I would spend the time to dismantle it and learn what you can about how it functioned, then take the parts to the scrap yard.
The tiller is the only thing that I would consider trying to salvage.
Thanks for seconding my earlier suggestion about using the tractor as a teaching tool. I made that suggestion before I saw the picture Jacob posted.
I admire Jacob's enthusiasm for machinery and I would rather see him sink his money into his Yanmar or another tractor that is a candidate for rehabilitation.
   / Burned JohnDeere 4100 #32
Agreed.
Well, after i take the Deere apart for experience, I know a guy who has 2 larger Simplicity tractors around the size of my Yanmar that are canidates for restoration. He is the guy i got my 9518 from. Ive been looking on craigslist lately but not much in need of work since most were purchased in the summer and are sitting in peoples shops now. I would love to fix the tiller since I do rototilling in town during the spring. This spring i know im going to borrow my grandpa's rototiller for my Yanmar but next year, I would love to use my own. That and my focus this year money wise is my invention and once that is all built and painted, I can start on saving for the tiller.
I may be getting the Deere out of that mess tomarrow. I plan to fix up the tiller for the Yanmar. Going to use my Yanmar anbd the neighbors BX24 to pull it out of there. The insurance got him the BX24. It is pretty nice. It came with a FEL and Backhoe. I plan to take pictures of the operation.
Havent got it yet, Ford is still investigating to really see if his F350 started the fire. He will call when I can get it out.
   / Burned JohnDeere 4100 #36
If you decide to use parts or even decide to give the whole tractor rebuild a shot, and you need more parts, the one I have has a lot of good parts on it. It was sitting next to the barn when the barn burnt and actually had a little bit of green paint (and yellow on the finish mower) that made it thru the fire. In my opinion, this one wasn't worth rebuilding, but it does have a lot of good usable parts.
David from jax
   / Burned JohnDeere 4100 #37
Jake,
You may need to find another gearbox for the tiller(or at least watch it in use). I think they used heat treated(hardened) gears, and a slow cooling would make them soft. If you have a slip clutch, there wouldn't be much of a consequence if they failed, though.
Chris
Well, yesterday, I went down there to pull it out. I got the roofing off of it. There wasnt much of the tractor left underneith. The rototiller appears to be in good shape. At first, I planned to use my pallet forks on my Yanmar to pick up the tiller and haul it home. I tried it and the front end of the tractor went up into the air. So we used the neighbors new BX24 to pull it out. Then I tried again with the forks but came to the same result. I used the field brakes to get to the gravel parking lot and took off the forks and used a pin to hold the tiller to the top hook of my imatch. That got it home. Then we tried to get the tractor out of the barn mess. We tried the BX but it wouldnt pull it. We tried the neighbor's new side by side, that spun its tires. So we were left with my step Dad's Dodge 3500 4x4. That pulled it out. In so, the front wheels came off. So I looked over the tractor. The transmission case was gone in places, the aluminum had melted off exposing the tranny gears. The tractor was really bent up, hood had suffered from the roof falling on it, the frame was so soft that the tractor would bend in the middle with little pressure. The tractor was officially garbage at this point. It would be pointless to take apart as it is missing so many parts and the aluminum parts are in puddles. Some of the hydraulic fittings were gone as well. The next thing I wanted was the grill guard for my Yanmar. I took that off. Then I wanted the Bucket off the FEL. I figured that if it was unsellable, I could make it fit onto my dad's 3720 as a dirt bucket. I got that off. It was really anoying, one pin came out real easy, the other had to be beat out and un burried. Underneith the tractor was a puddle of aluminum, Im pretty sure that was the tranny case. I hauled that home with the BX. The neighbor wanted the 3 point off the tractor since his BX diddnt come with one, so i worked on it for a while but couldnt get them off. Last thing i wanted was the ROPS for my Simplicity. I got all but 1 bolt off and used the BX to push and pull it until it fell to the ground. Then I hauled that home. It was getting dark so I drove home on my Yanmar. This morning, I went out to see my new, burnt implements. The tiller looks to be in pretty good shape. There was 1 or 2 bolts that are compleatly melted on it so it will be a lot of fun to take that apart. The bucket looks to be in good shape although the cutting edge and the side is bent from the heat of the fire. I plan to test it out on a Johndeere 2210 with a FEL to see how strong it is. Then maybe add some welds then powder coat it in Johndeere Green paint. The ROPS seem to be in the best shape. The Lights on it were compleatly gone, just 4 bolts were left. Today, I am going to grind the rust off the grill guard and paint it. I cant wait to put it on my Yanmar.
I just came in from working on the grill guard. Got the rust off it and bent it strait. I just painted it black. It will look good on my Yanmar.
   / Burned JohnDeere 4100 #40
Not trying to be crass here, but what part of "JUNK" do you not understand? :D :D :D
2001 Acura MDX SUV (A55758)
2001 Acura MDX SUV...
UNUSED LANDHONOR BH-12-72D BACKHOE DIGGER ARM (A54757)
UNUSED LANDHONOR...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2014 Dodge Charger Sedan (A55758)
2014 Dodge Charger...
2019 TAKEUCHI TL8 SKID STEER (A52705)
2019 TAKEUCHI TL8...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2008 DRAGON 150...
