Burn Piles for Beginners
/ Burn Piles for Beginners #41
We've been known to have a few bonfires now and then....
/ Burn Piles for Beginners #43
Nice pics Skypup -- I see your preferred starting method involves an old tire;)
Out of curiousity, how long did it burn with those big pieces?
/ Burn Piles for Beginners #44
The only way to get a good fire going with lots of stumps and large trunks is to use a tire or two, the burning pieces fall down into the pile and get it going from underneath where the heat pulls in the oxygen.....
A burn like that takes about two-three days of pushing in the outer circle into the middle and then the ashes are hot for at least 10 days - something to consider and manage.
/ Burn Piles for Beginners #45
Be aware of local codes. Around here, using a tire to start a pile will cost you $500 and up. Not commenting on good or bad, just be aware... :)
Pete
/ Burn Piles for Beginners #46
True, but one burnt out used tire is better (and cheaper) than 15 gallons of diesel fuel in my book.... :D
/ Burn Piles for Beginners #47
Yep. Just don't want anyone getting "burned" when a neighbor calls in the black smoke from the tire. Tire is cheaper than fuel, fuel is cheaper than fine, check your local rules as this is indeed a YMMV scenario. I use my used hydraulic oil to start stuff, as I think I posted in this thread earlier.
Great pix, SkyPup you got it going on! What's in the gallon container hanging form the ROPs ?
Pete
/ Burn Piles for Beginners #48
Tires work ok, but I hate having to clean up the wire that they leave behind. I only use them to get rid of them, but prefer to start a fire with some dry kindling and work up from there.
Also, punched a hole in my front screen pushing the fire together like skypup is doing. Didn't go through the radiator (would have had to go through the oil cooler first :( ) so I was lucky. I need a better guard, which I keep thinking about but don't get a roundtoit. :D
/ Burn Piles for Beginners #49
Pete
ICE WATER because it was so extremely hot out that day!!! :D
/ Burn Piles for Beginners #50
There is now a depot near me that will take tires for free again so I have a load scavenged off the property to take this weekend. Around here those big chunks would be firewood rather than burn pile:eek:
/ Burn Piles for Beginners #51
When I burn I keep spraying water on the fire. That way I have total control of how hot the fire gets. I keep the fire in check and don't let it get too hot.
Me too that works great we have to have a hose handy to burn anyway by law usually. (I didn't have a hose when I did the tires it was an open burn in a snow covered field in a big pit)
One time I thought I would out smart the law and burned some tires after dark after they had givin me permission to burn after sunset but I had to pull the tires out of the pit or get a big azz fine.
So soon as it got dark naturally I threw em all back in and after about 20 minutes I was a nervous wreck you could see that huge black cloud of smoke and fire going straight up all the way to town nobody showed up luckily. I wont be doing that again.
Steve
/ Burn Piles for Beginners #52
I love cleaning and burning reminds me of on the ranch with mom & dad. They used to burn together and have fun doing it.
2022 FORD F-750 SUPER DUTY DUMP TRUCK (A63276)
2022 FORD F-750...
2016 Ford F-550 4x4 Venturo ET25KXX 2 Ton Crane Service Truck (A61573)
2016 Ford F-550...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
Pemberton Inc Komatsu Grapple Bucket (A64194)
Pemberton Inc...
2011 Autocar ACX64 Xpeditor coe t/a refuse (A62679)
2011 Autocar ACX64...
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
