Burn Barrel
   / Burn Barrel
Got lucky as I found a 45 gal barrel that I had forgotten I had hidden away.
Cut the top off and there is no rust, next is to bore out the breather holes.
I like 3 at bottom and 3 more about 1/3 high staggered from the bottom ones.
I use a 1 1/2 core drill for those which makes a vert neat looking burn barrel.
I will paint the outside with black hi temp stove paint hoping to extend the life as well as having a good looking 'tool'.
I followed your air vent layout on my 55 gal barrel. Set it on a square of walkway grate to keep it off the ground. I'll be hoping for a couple of years out of this one. Meantime, I'll keep my eye out for a short section of 36" pipe, or something similar like the SS wash tub.
   / Burn Barrel #52
Ive seen some made out of culvert pipe also .
   / Burn Barrel #53
100% Stainless burn barrel from burnrightproducts.
It's actually an incinerator and burns so hot that there's no smoke once it reaches temperature within a few minutes. Also just leaves ashes due to maximum inceneration. Reaches 1800 degrees. The air vents are what makes it work.
I love mine. Lasts for many years. 20150525_195104.jpg20150525_202210.jpg20150525_195055.jpg
   / Burn Barrel #54
I have no idea about what our burn barrel laws are here.............but I don't suspect there are any. We get burn bans and warnings depending on weather conditions periodically and you have to have a permit to do any actual land burning. I've burnt some large brush piles before. Never had an issue but can see the potential for problems and I just don't do it anymore. But, I do burn paper and card board trash every weekend on the ground. It makes a mess. Have been looking for a burn barrel but someone above mentioned an old wood stove. I have one just sitting out in the woods. I think I will definitely set it up for burning trash!
The laws even here that govern aspects of rural living are oppressive in my opinion. But it sounds like I'm very very lucky to live where I do compared to some of you other guys. Living in a "backwards" state has its advantages.
   / Burn Barrel #55
I look at it with the opposite view... I live in a State that treats me as an adult.
I don't need to have every aspect of my life regulated by other people, from the Big Smoke (city) or Green Party, making laws to justify their own existence.
   / Burn Barrel #56
That's kind of my point. By U.S. standards states like South Carolina are considered backwards and backwoods partly because our government does not seek to control every aspect of my life and can't exactly afford to. It is more intrusive than I want it to be and getting worse every day, but again, pretty hands off compared to the west coast and north east.
   / Burn Barrel #57
Made several out 250 old oil drum, think it's 14 ga. I cut two big holes out on the narrow side, used the cut out pieces for covers. mounted it on runners so I could get tractor folks under it, when full of burt trash take it down back to empty it. It last around 5 years, depends on how much nuclear radioactive wastes I incinerate in it.
   / Burn Barrel #58
I'm going to try to get the old wood stove out of the woods with my tractor this weekend but I will be by myself so it might be tough. My only concern about using an old wood stove to burn trash is where to put it. Can't move it easily like I could a burn barrel. I want it close enough to be easy to access but it will be a bit unsightly so don't want it right next to the cabin. Also not sure how much trouble it will be to load and clean out but I'd guess it will reduce stuff pretty efficiently.
   / Burn Barrel #59
I set a tire on fire last night in protest of all the regulation all you have to deal with
   / Burn Barrel #60
I used to work for the DEQ Air Quality Division. We got a request from a farmer to do a controlled burn, which was acceptable under the regs at the time. He got permission; only thing, there just "happened" to be a cache of old automobile tires in the mix. You could see the black column of smoke for 30 miles.
Uni-Carriers S1S1L15NV 3,000lb Electric Forklift (A55851)
Uni-Carriers...
GMC 2500HD 4wd Service Truck (A55315)
GMC 2500HD 4wd...
2020 Freightliner M2 106 Elgin Whirlwind Series MV Street Sweeper Truck (A55852)
2020 Freightliner...
Rainbow Self-Propelled Volume Gun (A53317)
Rainbow...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
Sakai SV505 Vibratory Roller (A53317)
Sakai SV505...
