Buried downspout
/ Buried downspout #1
JimBinMI
Coldwater, Michigan
2014 Kubota BX25D-1, 2014 Kubota BX1870
Hey all,
We're doing some landscaping at one end of the house where the downspouts from the eves comes down and angles then empties on the surface of the ground. I would like to bury perforated pipe and have the water drain that way, so that it dissappears into the ground. Any ideas on what type of pipe to use and how far to run it or how deep to bury it?
Could I use one of those 3 pt. implements to dig the spot for it, I can't remember the name of it but it looks like a narrow plow that appears to go fairly deep.
Any suggestions would be appreciated!
Thanks, JimBinMI
We boys and our toys!
/ Buried downspout #2
Jim,
I would have it come out at grade down aways if you have a slope. If you are going to bury the whole thing you will need to put in either a french drain or a leach line to hold all the water during a downpour.
/ Buried downspout #3
JimBinMI, I think the implement you're talking about is the "subsoiler." And you can make a bit of a narrow trench with it all right, but I agree with Von; think you need to put in a French drain.
Bird
/ Buried downspout #4
I agree with Bird it sounds like your looking for a sub-soiler. I had a hard time finding one in my area until I was explaning to someone what it looked like and learned that most of the folks around here call it a "ripper". Once I used the local term I found it much easier to locate one in my price range.
A single heavy duty ripper (really beefy one) requires min of 20hp. The economy ripper requires less hp.
Kevin
/ Buried downspout
Von,
OK, don't know what a "French Drain" is or a "leach line"!
I do know that about half of my front roof line empties into a downspout that goes into the ground and comes out (just can barely see it at the surface about 50 ft. away.
My plan was to not have the water pour into the area that we are going to landscape with plants, trees and mulch. It does come out on a slope. I suppose that I could just extent the downspout and cover it with mulch in the area to be landscaped, if that didn't look too goofy!
By the way, the implement that I was thinking about was a Middlebuster, TSC advertises it as a one row 15" plow, price is/was in the old ad I found $89.99
JimBinMI
/ Buried downspout #6
JimBinMI, I have one of the Tractor Supply middle busters ($99.99 in my 1995 catalog which is what I paid for it that year). I use it occasionally to make a trench and I use it to dig my potatoes. On the same page of the catalog, they have a subsoiler for $139; narrow shank, 36# heavier, about 7" taller (get deeper in the ground?), etc. I occasionally take the plow off my middle buster and bolt on a single heavy duty ripper tooth to dig deeper, narrow trenches.
Let's see if I can explain a French drain, or if someone can correct me. You dig a trench 1' to 2' wide and deep, put a little crushed rock in the bottom, lay in perforated pipe (with your downspout running into that perforated pipe), then cover it with crushed rock, put some kind of screen, net, roofing felt (I've known of various materials used), over that, then cover it with dirt. In other words, you're making a leach field very similar to the one a septic system uses. Size depends upon how much water you expect to run into it. They are not used much in my part of the country, so maybe someone else can tell you more, but they are occasionally installed parallel to the building, i.e., around the foundation of a slab foundation building to keep it watered so the ground doesn't dry out and let a foundation settle and crack.
Bird
/ Buried downspout #7
Four inch flex drain (aka 'Big O') works well. It comes in perforated or unperforated. The perforated can be used for a leech line. A leech line is just a length of perforated pipe. The line usually is fairly large diameter to provide some storage capacity, which allows time for water to percolate into the soil.
A closed system has to have storage capacity to allow for wet years when percolation rates are low and for heavy rainfalls. A French drain is something that provides storage capacity. As far as I know, it's a pit in the ground that is surrounded by sand is filled with cobblestones, or can have a cavity made with cement block walls (the joints are not mortared and the holes face outward). What distinguishes a French Drain is that it has an impervious bottom.
A French drain usually is used for gray water or small flow septic uses. The idea is that the impervious bottom forces waste to percolate sideways through sand before it can enter the surface water table. You shouldn't have to worry about water table contamination from roof runoff, and an ordinary leeching pit (without an impervious bottom) would work.
An open system is easier to design than a closed one. The idea is that water can run out on the surface if the storage capacity is exceeded. A simple system might be: Take a 55-gallon drum and cut a hole for the fill pipe in the side near the bottom. Dig a pit where the ground level is below the downspout. The pit should be deeper than the drum is tall. Dig a trench to the pit for the feed line, install the drum (bottom up and without the top) in the pit, and run perforated drain line to the drum. Install a sizable vent line from the drum to ground level and backfill. Any excess water will exit the system through the vent. It's a good idea to screen the vent to keep out bugs and small animals.
If you're in a snow area, keep in mind that these systems do freeze, and your spring roof runoff will happen before the system thaws out. The only way to keep such a system open is to run the feed line straight down from the downspout to below frost level, and insulate the upper section. I don't think that's a good idea, because a joint failure could put a lot of water right on the middle of a foundation wall. I'd just put up with the freezing and disconnect the downspout after freeze up.
Another version of a system might use a drum for storage, and then run a leech line from the top of the drum. Then, you've got gray water storage, and you could install a pump and use the stored water for landscape plants. Extra care should be taken using even roof runoff gray water for food crops.
Keep in mind that there may be local codes that govern the design and installation of gray water systems--even for roof runoff.
/ Buried downspout #8
Jim, I have installed many buried downspouts and I do it this way. First I only use schedule 40 pipe since it only cost pennies more. Anything less can get crushed with heavy equipment driving across it; since it is only buried a few inches below the ground surface. Extend you pipe at least 6'-8' beyond the house to properly drain the water away from the house. At the end of the pipe I install a small drain basin & grate that is attached to the 3" or 4" schedule 40 pipe and place the top of the drain grate at ground elevation. The force of the water will push the water up thru the drain grate. The best way to do this is with a narrow backhoe bucket or the old fashion maddox. You need to install the pipe just below the ground surface allowing the drain grate to be flush with the ground and allowing a slight pitch of the pipe. A french drain would never allow for all the volume of water. Good luck and don't let anyone talk you out of anything less than schedule 40 pipe(either 3" or 4"), since I have had many people use something different and have afterwards said "you were right" when the equipment crushed their pipes.
/ Buried downspout #9
I believe that sounds like the best idea, yet, Jon S.
Bird
/ Buried downspout #10
Just a quick comment: I agree with the suggestion. From the original question, I thought there was a problem with simply letting the runoff go on the ground but further away from the house. Some storage capacity (pit or lines) would eliminate runoff on the ground from moderate rainfalls.
Trying to be helpful, I'll note that there is an assumption that 6' - 8' from the house would be below the bottom of the downspout. If the drainage grate isn't below the downspout, water will come out the downspout unless the spout/drain pipe joint is watertight. Some rural houses weren't built with the best grading.
We went about 20' under a porch and across a drive and have maybe 3" - 4" of angle. The drainpipe under the porch actually is above ground level. Some runoff drains into low spots in the yard, but the angle isn't enough to give good drainage. Some of it runs back and down the drive. Some of it drains back into the trench under the drive, but at least it gets to leech on its way back toward the house. The above ground section keeps it from coming all the way back to the house. All told, it's still a lot better than having a pool at the foot of the porch and across the drive. And, it's easier than re-grading the house. It's certainly easier than installing lines or a large capacity pit.
To illustrate storage capacity requirements: I built a gray-water leeching pit at our camp. The soil is sandy, and requirements for a pit rated at 1000 liters a day still are 4 x 2 meters by 1 meter deep. Two foot of the depth had to be above ground since our high water table is about 4 1/2 foot. The pit has an internal chamber of about a cubic yard and is surrounded by 8 yards of septic stone. This is a pretty big thing, but at a 1000 liter rating, it isn't going to handle runoff, except maybe from a playhouse. We use the drum type
dry-well I described for laundry, dish water and sump discharge at our other place. It's appropriate for gray that you can't just run out on the ground. It still fills up on heavy laundry days.
I don't know how strong schedule 40 pipe is. I was looking for small diameter steel culvert to run under the drive, but couldn't find any. I ended up building a 3 sided box from 2"x 6" and running 4" flex drain through it as a temporary measure. That area of the drive doesn't get much traffic, but the tractor and 1/2 ton haven't crushed the flex drain yet. Sometimes temporary becomes permanent.
/ Buried downspout #11
JimBinMI-Sounds like you are getting great advice from people who know. I would only add that if you use perforated pipe get the kind with a silt sock covering. Could be called something else in other areas. Here it is a cloth cover that keeps silt from clogging your drain pipe. We use it for foundation drains as well as landscape situations here.
/ Buried downspout #12
JIM I USE 4" CORAGATED SOLID BLACK PIPE WITH EITHER A 90 DEGREE ELBOW TO A 4" GRATE WITH A SMALL WEEP HOLE IN THE BOTTOM OF THE ELBOW, OR I HAVE ALSO USED A DRAIN CATCH BASIN WITH MANY HOLES DRILLED IN THE BOTTOM OF THE BASIN WITH GRAVEL OR PEA STONE UNDER THE BASIN, BE SURE TO PITCH YOU PIPE PROPERLY THE WATER RUNNING OUT WILL RISE OUT OF THE GRATE UNDER PRESSURE AND THEN THE REMAINING WATER WILL SLOWLY WEEP OUT THE BOTTOM .ALL OF THESE PIECES CAN BE FOUND AT LOWES OR HOME DEPOT .I TO LIVE IN MICH. AND DEPENDING ON THE WINTER ,ROOF PITCH, AND AMOUNT OF RUNOFF THAT THIS GUTTER COLLECTS IT CAN FREEZE UNDER GROUND SO BE SURE TO DRAIN IT PROPERLY.
/ Buried downspout
Everyone,
Thanks for all of the responses, really came through for me!
I haven't decided which way to do it yet but from all of these responses I have a lot of ideas.
I think that I'll start by checking with my township office for and codes that I have to follow and go from there.
JimBinMI
/ Buried downspout #14
JimBinMI, that's one advantage of living out in the country; there are no codes, you just do whatever you want to./w3tcompact/icons/smile.gif Of course, that's one of the disadvantages, too, like my new next door neighbor who hasn't even mowed his yard this year; prior owner kept a beautiful lawn, but I didn't know that kind of grass could get waist high./w3tcompact/icons/frown.gif
Bird
/ Buried downspout
Bird,
Aren't you in a township or something? How could you have no rules? There must be some rules, right?
Most people call where I live "in the country", I'm in an area zoned "Agricultural". I have a dairy farm on my block. Most parcels have 8-10 acres, across the road one has 50 acres, one 25 acres, obviously the dairy farm has more acres.
JimBinMI
/ Buried downspout #16
JimBinMI, there's no such thing as "townships" in Texas. And the nearest "city limits" are 10 miles away. Naturally, there are some state laws regulating septic systems or other sewage facilities, and if you have less than 10 acres, you have to get a permit, have an inspection, etc., but if you have 10 acres or more and do the work yourself, you don't even have to abide by those things if you stay far enough away from the property line, and don't run anything over onto someone else's property. When you get new water service, they tap the main and install the meter. From there on, you're on your own except for an inspection of new construction to check for cross connections and such. For new electric service, the electric company will tell you what kind of pole, weatherhead, ground rod, wire, conduit, etc. to the meter base and master panel. From there on, anything you want to do. And you wouldn't believe some of the things the prior owner did to this property. From a single 100 amp master panel, and a 100 amp breaker, he ran wiring to a 100 amp breaker panel in an old mobile home, ran another wire from that same 100 amp master breaker straight to a water heater in the mobile home, ran another wire off the same breaker to an outside security light, then put a 70 amp breaker in the master panel and ran wires overhead on a couple of 4 x 4 posts to a 200 amp breaker panel in the shop, and ran wires from that 200 amp panel underground (about 3" deep) to a 70 amp panel in the barn. I still haven't figured out why the whole place hadn't burned down before I bought it. I added a second meter, with master panel, for the shop and barn, and replaced everything below the meter base (including the pole it was on) on the original meter, upgrading it to 200 amp service (and replaced that ragged old mobile home with a new doublewide). As far as your residence is concerned, you can pitch a tent or build a castle or anything in between, modify it anyway you want, anytime you want. If you have insurance or a mortgage, those folks might put some restrictions on you, but that's the only folks who will.
Bird
/ Buried downspout #17
Or like the bumper sticker says,"Welcome to Texas, Now Go Home." Too many people moving in trying to make Texas like the state they came from. The Septic Tank rules are relatively recent. For years there were no rules there either. You can wire your own house, do your own plumbing, build your own house and roof it. The only rules that apply are covenents that have been placed on the land by a previous owner. I saw one once that said No Yankees could live there. Don't guess that held up too well in court.
/ Buried downspout #18
Yep, Wen, it's sure different from living in the city. My brother's not a professional draftsman, but both brothers used to be home builders, so he just drew up some plans himself, took them to a local bank, which promptly approved interim financing and we built his house. He contracted the pouring and finishing of a concrete garage floor, installation of the heating and air-conditioning system, and an aerobic sewer plant. We did everything else ourselves from the water meter and electric meter on. No permits, no inspections, no delays. I think the bank did send someone out to look at it when they changed from interim financing to a regular mortgage. And of course, we built it in a manner that would meet or exceed any building codes we know of.
It was a little comical when the young fellow delivering a load of ready mix asked where we were from, since he's used to slab foundations, and we built on a pier and beam with a 4' "basement" or crawl space like my brothers used to build in Alaska.
Bird
/ Buried downspout #19
JimBinMI said:
Bird,
JimBinMI
Nope:
It's a shame some folks don't know what freedom is.
/ Buried downspout #20
I just done this on my garage this past summer. I ran 3'' and 4'' PVC solid pipe to a drainage ditch about 25 feet behind the garage. Installed a line along each end of the garage and tied the four down spouts into the 2 lines.
Since I have the drainage ditch no French drain, gravel or perforated pipe was required.
I did not use the corrugated flexible pipe as that stuff is notorious for getting leaves caught in the ridges and plugging up the pipe.
2023 Ram 1500 Crew Cab - Built to Serve Edition (A66408)
2023 Ram 1500 Crew...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2012 FREIGHTLINER M2 6X4 T/A DAY CAB TRUCK (A66091)
2012 FREIGHTLINER...
2008 JLG 3246ES 32ft Scissor Lift (A64553)
2008 JLG 3246ES...
41in Metal American Flag (A65583)
41in Metal...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
