Bummed Beaver
/ Bummed Beaver #11
I have a Beaver which has an optional gear box with a standard size PTO to change the rotation to Clock Wise. Evidently, they came with the smaller splined PTO when new. Your best option would be to try to find a gear box to make the change, but they probably are very scarce. Good luck with this!
Thom
/ Bummed Beaver #12
Think of this... Most all of the brush hog gear boxes are (I wasn't paying attention is it right turn?) so the teeth on the gears are worn on one side only. If you find a used one and reverse the blades or fabricate your own new blades to work backwards on it you'll have brand new surface on your gears. It'll be a brand new mower at a 10 year old price. Am I right?
/ Bummed Beaver #13
I have a woods rm 48 with the small pto shaft for a beaver and its setup to run counter clockwise. if you can use a finish mower and are close to pittsburgh pa make me an offer. It works fine, could use some TLC but Ive used it the past 2 seasons.
Jim
stripercity@live.com
CATERPILLAR 108" WHEEL LOADER RAKE (A52707)
CATERPILLAR 108"...
2000 TEREX 60TON T560 REAR WHEEL DRIVE CRANE TRUCK (A59906)
2000 TEREX 60TON...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59906)
2007 FREIGHTLINER...
2012 Ford Transit Connect Cargo Van (A59230)
2012 Ford Transit...
