Built a custom adjustable trailer jack mount
   / Built a custom adjustable trailer jack mount #11
Could you please send me a link or model number to this jack? My trailer has this jack but it no longer works and I want to replace it with the same thing.
Not currently listed on their website.
Aaron Z
Yeah, apparently no longer available. Btw, I did get this installed...works like a charm, makes working with that trailer alot easier. I'll take some pictures and get them uploaded...completely forgot about this thread :)
--Wintermute
   / Built a custom adjustable trailer jack mount #13
Aaron Z
--Wintermute
Yeah I looked on Northern tools site as well and didn't find it. I figured with a model number I could do a google search. I typed Hydraulic Trailer jack in google and this was the third picture that popped up. I was shocked I actually found it.
Well thanks anyway.... It doesn't appear anyone makes a jack like this anymore. I'm not real sure what I'm gonna do. I need at least a jack that extends at least 30 inches to get it off my ball.
   / Built a custom adjustable trailer jack mount #14
Will an electric one work? There are several drop leg electric ones that should do the trick if you add a little bit to the drop leg part. One at Northern has a 18" stroke and a 6" manual drop. If you added another 6" to the foot, it could work well.
Aaron Z
   / Built a custom adjustable trailer jack mount #15
Aaron Z
Thanks, I'll have to check that out.
My biggest problem is the tongue weight I sometimes have on it. That is why I liked the Hydraulic jack. It handled it well and was easy to use. I also didn't need a battery to power it.
I've had as much 3900 lbs on the tongue...not intentionally but it has happened.
I'll check it out,
Thank you!
   / Built a custom adjustable trailer jack mount #16
It's a large dump bed trailer. Once I get it installed, I'll get some pictures of it mounted to the trailer and the trailer itself.
--Wintermute
Still waiting for the pics...zzzzzz
2025 MMS MS36C (A53317)
2025 MMS MS36C...
Insulation (A56860)
Insulation (A56860)
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2001 Ford F-650 Water Truck, VIN # 3FDWF655X1MA82619 (A57453)
2001 Ford F-650...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
New/Unused 4000PSI Hot Water Pressure Washer (A57453)
New/Unused 4000PSI...
