Building with Concrete Block
   / Building with Concrete Block #1
WVBill
Usa
Sold my Kubota B6100 when I moved to WA
I'm building a low (32" tall - 4 courses) concrete block wall. I have poured a concrete footer and am starting to lay the block.
I can't get the mortar to stick when I try to "butter" the end of the block. I spread it on but then as soon as I turn the block so the head face is vertical the mortar just falls off.
I've mixed the mortar per the quikrete directions (2.5 parts mason's sand to 1 part masonry cement) with water to the consistency of mayonnaise.
But it just won't stick...
What am I doing wrong?
WVBill
   / Building with Concrete Block #2
Butter the block that is already in place.
   / Building with Concrete Block #3
If it won't stick to your 'block already in place', play with your "consistency of mayonnaise".
Might be a smudge to thin.
   / Building with Concrete Block #4
It's too dry to stick. Add more water to your mix and it will hold allot better. Of course, just add a little water at a time to get it right. Too much water will ruin the strength of mortor, or turn it into soupl.
Eddie
   / Building with Concrete Block #5
Add a little Portland and some lime. Experiment with the mixture.
Application method is also important. The mortar sorta has to be pressed onto the block in one quick motion.
It takes a little practice.:D :D
Thanks, guys.
I played with the consistency of the mortar today - added a little bit of water and tried pressing it onto the block.
Managed to get a bit to stick but not the full 3/8 in. thickness the joint is supposed to be.
I've been forcing it into the joint from the sides and top - not the way to do it, I know....
I'll get a bag of portland this week and try adding some of that to the mix.
352 blocks to go. By the time I get to the top course I should have it figured out. :rolleyes:
WVBill
   / Building with Concrete Block #7
Don't rush ahead till you get that mortar to stick!
The Portland cement will add strength to the mix. Lime adds stickiness. Try using more mortar cement. Make real small batches till you get one to work. You can use a drill and little paint mixer and a milk carton or even smaller to practice with. Also let the mortar sit for about 10 minutes and then mix again to allow for better water distribution. Just make sure you keep track of the ratios and if in doubt go heavier on the mortar cement.
When applying the mortar it has to be a quick type slap shear motion.
Now please note: I am far from knowledgeable on this topic and do not intend to get more knowledge on using concrete blocks!!
   / Building with Concrete Block #8
"fluffy"
I once had a mason's mason tell me the mortar needed to be "fluffy". The mayo thing sounds way too wet from what I've learned. I'd think more like frosting.
Another thing is we wet down the blocks prior to using, hope this helps.
   / Building with Concrete Block #9
I don't know about concrete blocks, but when I've done stone masonary in the past, I learned to "throw" the mortar onto the stone to make it stick. You don't smear or press it on. You take the slice of mortar on the edge of the trowel, turn the trowl perpendicular to the block and flick your wrist to "throw" it against the rock (or in this case concrete). It should slide off the trowel and onto the block. Sorry I can't describe it better, but I think you'll find that most mortar mixtures, even a little wet or dry, will stick with this method. It takes a few tries to get your aim down.
And, yes, wetting the concrete a little will help, and will imporve the bond and curing of the mortar. It makes it dry more evenly instead of giving up all it's moisture to the block near the juncture of block and mortar.
Cliff
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
2018 Ford Transit 350HD Handicapped Van (A53422)
2018 Ford Transit...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A55788)
2009 Peterbilt 384...
Mobile toilet with shower (A55758)
Mobile toilet with...
UNUSED LANDHONOR AD-12-23C HYD AUGER (A54757)
UNUSED LANDHONOR...
35in Tooth Excavator Bucket (A55787)
35in Tooth...
