Building Tractor-loader-bachhoe Attachments
/ Building Tractor-loader-bachhoe Attachments #21
ya i had been looking for some of this myself, lot of these online metal places look really good till you hit the shipping....then ouch... i found a few pieces on amazon with free shipping and last time i found a place called low range off road which had freee shipping over 50.00 (not sure if its all the time or i hit a promo) but look into it. im also finding i have to take my 1 round stock down a little bit to slide in the dom...im using hot rolled and the scale makes it a bit bigger then 1'" pins might be a bit different i don't know
/ Building Tractor-loader-bachhoe Attachments #22
Been a little while since I've bought any material but I usually use onlinemetals.com or midwestmetalwarehouse.com for DOM and 1144 stress proof for making pins and bushings. It does require either the DOM be opened up or the pins turned down a bit to achieve desired clearance.
thanks to all of you looking and replying to my thread. i REALLY appreciate it!!! I know it helped me to buy the correct sized material.
thanks rob
bukitcase, thanks for the wheel cylinder hone idea. i have a hone that is at least 40 years old and it would work if off by a smidgeon. thanks for the idea. rob
/ Building Tractor-loader-bachhoe Attachments #26
If you're using DOM, the brake hone is only good for taking a VERY small amount off, if you have a lot to do I would recomend a reamer.
2017 Dodge Grand Caravan Van (A61574)
2017 Dodge Grand...
4004SFL (A59228)
4004SFL (A59228)
UNUSED IRANCH IRTPL 10000 LB TWO POST LIFT (A64281)
UNUSED IRANCH...
POWELL (4) ROW FERTIZER DISTRIBUTOR (A64280)
POWELL (4) ROW...
2012 Ford E-350 4x4 Terra-Hawk Mobile Surveillance Van (A61573)
2012 Ford E-350...
UNUSED WOLVERINE RSB78-78" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
