Building ToothBar need advice ..
/ Building ToothBar need advice .. #1
deerhunterf350
St. Louis, Mo
New Holland TC55DA
I have looked at the TB that JohnF_ASI built and going to use his idea.
Question is would 1/4" x 3" x 72" bar be heavy enough for use in the Bucket to weld Bar Stock to , or should I use 3/8" x 3" x 72" .
72" wide HD bucket on a TC55 , which from what I have been reading and from looking at the Specs that is a Strong Loader.
Thanks
/ Building ToothBar need advice .. #2
I would not use anything less than 3/8" x 3". In fact I would probably go up to 1/2" x 3". You want strength here without any twisting or bending. Thicker steel is the way to go.
/ Building ToothBar need advice .. #3
Less than 3/8" x 3" is increasing the risk of big warp when you weld the teeth on..
Going 1/2" might start to introduce the necessity to pre-heat before welding.
If your fit up tolerances are pretty tight, the 'pinching' effect of the teeth will help in minimising twist.
I'm pleased that you liked the design enough to use it..
/ Building ToothBar need advice .. #4
I suggest 1/2" stock, particularily with that 72" bucket.
I used 1/2 on my 48" and would have preferred 3/8 but for sure on a 72" use the 1/2 stock.
Misc. Pipe Lot 1 1/4", 2", and 3" Poly Pipe (A62679)
Misc. Pipe Lot 1...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
2017 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 FREIGHTLINER...
